扫一扫,分享给好友
我们有一个问题,一个更大的(4096字节)转移到EP0。在Windows 8和超高速,这种转移是失速控制转移。较小(64字节)传送功。和4096字节传输似乎是工作在高速模式的USB2.0端口。
捕捉厂商请求处理在转让这个尺寸的正确方法是什么? 下面的工作是什么? CYU3PUBGETEP0DATA(4096,计数,和ADCOUNT); 因为EP0大小设置为64字节,但整个传输更大,什么时候u***setup事件被称为?这是可能的,数据的酮基部分由每次调用getep0data收到,因此需要多个电话? 以上来自于百度翻译 以下为原文 We have an issue with a larger (4096 byte) transfer to EP0. On Windows 8 with SuperSpeed, this transfer is stalling the control transfer. Smaller (64 byte) transfers work. And the 4096-byte transfer seems to be working in High Speed mode on USB 2.0 ports. What is the proper way to capture a transfer of this size within the vendor request processing? Will the following work? CyU3PU***GetEP0Data(4096, count, &readCount); Since EP0 size is set to 64 bytes, but the entire transfer is much larger, when does the USB setup event get called? Is it likely that onyl part of the data is received by each call to GetEP0Data, thus requiring multiple calls? |
5个回答
关于这一点的更多信息。
通过高速端口,我可以读取整个4096字节。 使用超速端口,我可以读取512字节。不是1024。如果指定长度大于512,则调用CYU3PUBGETEP0DATA返回CyuU3pYErrOrthTimeOUT。 以上来自于百度翻译 以下为原文 A touch more information on this. With HighSpeed ports, I can read the entire 4096 bytes. With SuperSpeed ports, I can read 512 bytes. Not 1024. The call to CyU3PU***GetEP0Data returns Cy_U3P_ERROR_TIMEOUT if the length specified is greater than 512. |
我们仍然有这个问题。通过USB 3总线分析仪,我们注意到,由于某些原因,1024字节的超时传输。
- 还有其他人使用Windows 8吗?EP0转移有什么问题吗? 以上来自于百度翻译 以下为原文 We're still having this issue. With a USB 3.0 bus analyzer, we note that IN transfers of 1024 bytes time out for some reason. - Is anyone else using Windows 8? Any issues with larger EP0 transfers? |
微软说,一个已知的问题存在与Windows 8(消费者预览)和ASMedia控制器具有控制传输& gt问题;字节。这似乎并不是一个与瑞萨控制器问题。据他们说,这个问题有一个解决方案,将在未来的Win8发布。
以上来自于百度翻译 以下为原文 Microsoft has said that a known issue existed with Windows 8 (Consumer Preview) and the ASMedia controller that has problems with control transfers > 512 bytes. This does not appear to be an issue with the Renesas controller. According to them, the problem has a workaround and will be issued in the next Win8 release. |
这个问题有什么更新吗?
我赢了8441,我仍然不能发送配置描述符大于512字节。 以上来自于百度翻译 以下为原文 Are there any updates on this issue? I've win 8441 and I still can't send configuratin descriptor larger then 512 bytes . |
HTTP://Soalal.MSDN.MySo./FuMs/EN-U/WDK/THEAD/74097 A22-FAB2-440A8E17-6DD0C968 568/
上面的线程说,工作区将被添加到Windows 8的下一个版本。 你有没有测试过Windows 8发布预览版本? 以上来自于百度翻译 以下为原文 http://social.msdn.microsoft.com/Forums/en-US/wdk/thread/74097a22-fab2-440a-8e17-65dd0c968568/ The above thread says that the workaround will be added to the next release of the Windows 8. Have you tested with the Windows 8 Release Preview version. |
只有小组成员才能发言,加入小组>>
726个成员聚集在这个小组
加入小组1938 浏览 1 评论
1685 浏览 1 评论
3448 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1606 浏览 6 评论
1404 浏览 1 评论
GMT+8, 2024-6-26 08:17 , Processed in 0.774219 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
