我需要使用ST Visual Develop调试STM8L151,我已经安装并激活了cosmic编译器。
我的项目建立,但不会开始debuging。 我收到警告/错误''在运行应用程序之前,你应该先为项目选择一个MCU'' 进入项目设置,它不会让我选择任何MCU,我有一个空列表。在另一台PC上填充此列表。 尝试多次卸载并重新安装编译器和ide。 使用32位Windows 7 以上来自于谷歌翻译 以下为原文 I need to a Debug an STM8L151 with ST Visual Develop, I have the cosmic compiler installed and activated. My Project builds, but wont start debuging. I get the warning/error ''Before running the application, you should first select a MCU for the project'' Going to the project settings, it wont let me select any MCU, i've got an empty list. On another PC this list is populated. Have tried uninstalling and reinstall the compiler and ide multiple times. Using 32bit Windows 7 |
5个回答
你好,
看起来DAO DLL在安装过程中没有正确注册。如果您安装了STVD-4.3.5,请尝试从st_toolset / stvd / dao存储库手动启动ST Toolset.msi。如果它没有修复,我希望这至少会给出一个线索。 最好的祝福 以上来自于谷歌翻译 以下为原文 Hello, It looks like the DAO dll have not been correctly registered during the installation. If you installed STVD-4.3.5, try to manually launch ST Toolset.msi from the st_toolset/stvd/dao repository. If it does not fix, I hope this will at least give a clue why. Best regards |
嗨是的,使用4.3.5。
跑.msi安装程序,但它没有帮助。还有其他想法吗? 我在创建一个新项目时遇到类似的错误,我得到一个窗口,要求为项目选择一个没有列出MCU的MCU,OK按钮显示为灰色,窗口没有关闭或取消按钮,唯一的选择就是杀死进程。 卡尔。 以上来自于谷歌翻译 以下为原文 Hi yes using 4.3.5. Ran the .msi installer but it hasn't helped. any other ideas? I get a similar error when creating a new project, I get a window asking to select an MCU for the project with no MCUs listed the OK button is greyed out and the window has no close or cancel button the only option is to kill the process. Carl. |
你好,
请您先检查以下文件是否存在: dao350.dll,dao360.dll和dao2535.tlb in 'c:/ Program Files / Common Files / microsoft shared / DAO''或'c:/ Program Files(x86)/ Common Files / microsoft shared / DAO'',具体取决于您的操作系统版本。 如果存在文件,请尝试通过命令提示符手动注册它们: regsvr32''c:/ Program Files / Common Files / microsoft shared / DAO / dao360.dll'' 以上来自于谷歌翻译 以下为原文 Hello, May you please then firstly check the presence of following files: dao350.dll, dao360.dll and dao2535.tlb in ''c:/Program Files/Common Files/microsoft shared/DAO'' or ''c:/Program Files (x86)/Common Files/microsoft shared/DAO'', depending on your OS version. If files are present, try to manually register them, through a command prompt: regsvr32 ''c:/Program Files/Common Files/microsoft shared/DAO/dao360.dll'' |
是的dao350.dll,dao360.dll和dao2535.tlb存在于C: Program Files Common Files microsoft shared DAO目录中
根据建议手动注册它们,不幸的是没有变化。使用Windows 7 32位最新补丁。 以上来自于谷歌翻译 以下为原文 Yes dao350.dll, dao360.dll and dao2535.tlb are present in the C:Program FilesCommon Filesmicrosoft sharedDAO directory Registered them manually as suggested no change unfortunately. Using Windows 7 32bit upto date with patches. |
嗨,
我遇到了同样的问题。你一年前解决了吗?你能分享吗? Thnks。 以上来自于谷歌翻译 以下为原文 Hi, I faced the same problem. Did you solve it a year ago? Can you share? Thnks. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2741 浏览 1 评论
3244 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1813 浏览 1 评论
3653 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
203浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
356浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
446浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-26 19:07 , Processed in 1.248424 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
