电子发烧友论坛|
我有很多麻烦连接MPLAX X到我的新皮卡3。有时它有效,有时不起作用。我得到的错误是“连接失败”。我通常可以通过拔出USB端口的皮卡并再次插入它来工作。我必须不止一次这样做。有时我也要把它从测试电路中拔出来。我还没能确定一个能让它再次工作的模式。我用的是3.55,但是以前的版本有问题。
以上来自于百度翻译 以下为原文 I am having lots of trouble connecting MPLAB X to my new PICkit 3. Sometimes it works and sometimes it does not. The error I get is "Connection Failed." I can usually get it to work by unplugging the PICkit from the USB port and plugging it back in again. I have to do this more than once. Sometimes I have to unplug it from the test circuit as well. I have not been able to determine a pattern which always gets it to work again. I am using 3.55 but have had the trouble with the previous version. |
7个回答
电脑细节?有旧的吗?它起作用了吗?它在另一台电脑上工作吗?
以上来自于百度翻译 以下为原文 The Computer details? Was there an old one? did it work? does it work on a different computer? |
我几乎总是得到与PICTIT3相同的响应。我发现它的唯一方法是最好跟随3的表中的顺序。在构建之后,选择CIPIT3作为调试器或程序员,连接USB电缆,与附加的目标板,打开目标电源。2亚历克的问题
以上来自于百度翻译 以下为原文 I practically always get the same response with the Pickit3. I have found the only way it works the best is to follow the sequence in the sheet that came with the 3. After a build, select Pickit3 as Debugger or Programmer, connect USB cable, with attached target board, turn on target power. Never had the problem with the 2. Alec |
感谢YouKurZMAN为您的答复…操作系统是Windows 7 Pro,32位。它比我以前的3点要好得多。我有一台电脑,没有改变操作系统。这个问题也发生在MPLAB X 3.51上。
以上来自于百度翻译 以下为原文 Thank you NKurzman for your reply... The OS is Windows 7 Pro, 32 bit. It worked a lot better with my previous PICkit 3. I have one computer and have not changed the OS. The problem also occurred with MPLAB X 3.51. |
嗨,亚历克,谢谢你的回复。它通常发生在成功的调试会话之后,我已经做了一些代码更改。我尝试加载新的调试代码,系统失败。我会尝试您的建议,并张贴结果。
以上来自于百度翻译 以下为原文 Hi Alec, Thank you for the response. It usually happens after a successful debugging session after I have made some code changes. I try to load the new debug code and the system fails. I will try your suggestion and post the results. |
尝试编辑注册表以禁用PK3上的增强型电源管理。参见:HTTP://www. MyCHIP.COM/FUMMS/M83106ASPX
以上来自于百度翻译 以下为原文 Try editing your registry to disable enhanced power management on the PK3. See: http://www.microchip.com/forums/m883106.aspx |
尝试添加铁素芯到USB电缆或使用一个有一个…
以上来自于百度翻译 以下为原文 Try adding a ferrite core to the USB cable or use one that has one.... |
看来我已经解决了这个问题。虽然我不确定这两者中的哪一个——如果两者都是必需的……1,使用设备管理器,我在工具-选项-嵌入式-通用设置中启用USB永远不下电):我启用了“保持对硬件工具的主动连接”,看起来我也需要PICkit迪斯科。当MPLAB启动时,从计算机上启动。
以上来自于百度翻译 以下为原文 It looks like I have fixed the problem. Although I am not sure which of these two did it - of if both are necessary... 1) Using Device Manager, I enabled the USB to never power down 2) in Tools - Options - Embedded - Generic Settings: I enabled "Maintain active connection to hardware tool." It also looks like I need to have the PICkit disconnected from the computer when MPLAB starts. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
501 浏览 0 评论
5808 浏览 9 评论
2350 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3543 浏览 3 评论
1155浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1119浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
887浏览 1评论
501浏览 0评论
/9
GMT+8, 2025-12-12 05:28 , Processed in 1.685957 second(s), Total 87, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1071
