电子发烧友论坛|
大家好,
有谁知道如何更改Vivado TCL控制台窗口中的字体/字体大小? 我有一个2016.1的安装,我将字体从Courier更改为Consolas并稍微缩小尺寸以增加线路上的信息密度,但我最近安装了2016.4并且它已经使用了更大的Courier字体限制 屏幕上显示的信息。 我在2016年以某种方式改变了它。但似乎无法找到它的位置。 有什么想法/建议? 西蒙 以上来自于谷歌翻译 以下为原文 Hi all, Does anyone know how to change the font/font size in the Vivado TCL console window? I have an install of 2016.1 where I changed the font from Courier to Consolas and shrunk the size down slightly to increase the density of informatio on a line, but I've recently installed 2016.4 and it has gone to a much larger Courier font that limits the information shown on screen. I have somehow changed it in 2016.1 but can't seem to find out where. Any thoughts/suggestions? Simon |
3个回答
你好@ simdav_dlp
在Vivado GUI中,请转到工具 - >选项,这将打开一个窗口,其中转到文本编辑器 - >字体和样式,如下所示: 问候 罗希特 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @simdav_dlp In the Vivado GUI please go to Tools -->Options , this opens a window in which go to Text Editor --> Font and Styles as shown below: Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- View solution in original post |
你好@ simdav_dlp
在Vivado GUI中,请转到工具 - >选项,这将打开一个窗口,其中转到文本编辑器 - >字体和样式,如下所示: 问候 罗希特 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi @simdav_dlp In the Vivado GUI please go to Tools -->Options , this opens a window in which go to Text Editor --> Font and Styles as shown below: Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
罗希特,
这似乎改变了它。 这是相当奇怪的,因为我会从上下文中想到选项卡在(文本编辑器)中它会影响文本编辑器而不是TCL控制台窗口。 这可能就是我从未找到它的原因! 问候 西蒙 以上来自于谷歌翻译 以下为原文 Rohit, That seems to have changed it. Which is rather odd as I would have thought from the context that tab is in (Text Editor) that it would affect the Text Editor and not the TCL console window. That's probably why I never found it! Regards Simon |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 00:41 , Processed in 0.724492 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6677
