我有一个程序文件,在模拟开始时必须存储在BRAM中。
要加载BRAM,我无法重复使用我的传统测试平台任务,因为内存组织不同,因为这些任务是为ASIC RAM IP编写的。 我们正在尝试使用Xilinx FPGA启动产品原型,因此RAM IP与BRAM交换。 如何在模拟中加载带有pgm文件的BRAM? 以上来自于谷歌翻译 以下为原文 I have a program file which has to be stored in BRAM when simulation starts. To load the BRAM, am not able to re-use my legacy test bench tasks because the memory organization is different as those tasks were written for an ASIC RAM IP. We are trying to bring-up a prototype of the product using Xilinx FPGA, so RAM IP is swapped with BRAM. How to load the BRAM with pgm file in simulation? |
2个回答
@wpravinyou可以编写一个verilog任务,它读取现有文件,重新排列数据并“强制”信号进入bram以高速加载它们,然后“释放”并让模拟运行。
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 @wpravin you can write a verilog task which reads the existing file, re-arrange the data and "force" signals into the bram to load them at a high speed, then "release" and let the simulation run. - Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
@muzaffer感谢你的输入。
是的,我可以根据要求编写任务来重新安排数据。 我拥有的模型是“PNL_BRAM_256X16_sim_netlist.v”,这是实例化多个基元的网表模型。 因此很难安排数据。 我想知道BRAM的verilog行为模型是否可用以及如何生成它? 以上来自于谷歌翻译 以下为原文 @muzaffer Thanks for your inputs. Yes, i can write a task to re-arrange data as per requirement. The model which I have is "PNL_BRAM_256X16_sim_netlist.v", and this is netlist model with multiple primitives instantiated. So it is difficult to arrange data. I would like to know whether verilog behavioral model of BRAM is available and how to generate it? |
只有小组成员才能发言,加入小组>>
2215 浏览 7 评论
2640 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2119 浏览 9 评论
3188 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2243 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
488浏览 1评论
1566浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2215浏览 0评论
540浏览 0评论
1701浏览 0评论
GMT+8, 2024-6-26 07:20 , Processed in 1.232972 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
