嗨,我完全自动化了混频器/放大器模块的校准增益压缩测量(GCX),但只想测量SC21。
分析仪经过校准并测量完全校正的GCX扫描,但我不希望分析仪测量反向(SC12)方向,也不需要回波损耗(SC11和SC22)。 我倾向于将完整的GCX校准降级为“增强响应校准”。 我可以手动设置“增强响应校准”仅用于SC21扫描,但无法远程执行此操作。 是否有参数可以关闭SC12扫描? 要从前面板禁用反向扫描,请通过Response - > Cal - > Mange Cals - > Correction Methods ...导航到“Select Calibration Type”页面,然后取消选中所有校准类型。 校准类型产生“SMCRsp”。 我使用校准类型作为参数,但这会打开反向测量。 我附上了一个单词doc,其中包含“选择校准类型”页面和上面的文本。 谢谢你的帮助。 Ronel PNA-X型号N5242A固件:A.09.80.16选项:080,083,400,419,423内存版本:59.0(发布) 以上来自于谷歌翻译 以下为原文 Hi, I am fully automating a calibrated gain compression measurement (GCX) for a mixer/amplifier module but only want to measure SC21. The analyzer is calibrated and measures a fully corrected GCX sweep but I don't want the analyzer to measure the reverse (SC12) direction and I don't need return losses (SC11 and SC22). My preference is to downgrade a full GCX calibration to an "Enhanced Response Cal". I am able to set the "Enhanced Response Cal" manually for only SC21 sweep but unable to do this remotely. Is there a parameter to switch off the SC12 sweep? To disable the reverse sweep from the front panel navigate to “Select Calibration Type” page by Response -> Cal -> Mange Cals -> Correction Methods… and uncheck all the calibration types. The Calibration Type results in “SMCRsp”. I used the Calibration Type as a parameter but this turns on the reverse measurements. I've attached a word doc with a picture of the "Select Calibration Type" page and the text above. Thanks for any help. Ronel PNA-X model N5242A Firmware: A.09.80.16 Options: 080, 083, 400, 419, 423 Build: 59.0 (Release) 附件 |
6个回答
我假设你正在使用SCPI?
我同意很难找到GCX cal命令。 GC设置命令主题下有一个小注释:GCX设置混音器使用Sense:混音器命令使用* SMC命令校准*和引导命令所以我认为这是您正在寻找的SMC命令:http://na.tm。 agilent.com/pna/help/latest/Programming/GP-IB_Command_Finder/Sense/MIXerSCPI.htm#Reverse 以上来自于谷歌翻译 以下为原文 I assume you are using SCPI? I agree the GCX cal commands are difficult to find. There is this little note under the GC Setup commands topic: GCX Setup Mixer using Sense:Mixer commands Calibrate using *SMC commands* and Guided commands So I think this is the SMC command you are looking for: http://na.tm.agilent.com/pna/help/latest/Programming/GP-IB_Command_Finder/Sense/MIXerSCPI.htm#Reverse |
testd018 发表于 2019-4-19 15:02 谢谢。 这非常有帮助。 我假设GCA会有一个类似的SCPI命令。 Ronel 以上来自于谷歌翻译 以下为原文 Thanks. That was very helpful. I assume that there will be a similar SCPI command for GCA. Ronel |
你是说将来某天会有“会有”吗? 如果是这样,我不会打赌它。 以上来自于谷歌翻译 以下为原文 Do you mean 'there will be' as in someday in the future? If so, I would not bet on it. |
如果你的意思是'将会有'在将来的某一天,我不会赌它。 以上来自于谷歌翻译 以下为原文 If you mean 'there will be' as in someday in the future, I would not bet on it. |
只有小组成员才能发言,加入小组>>
1119 浏览 0 评论
2315 浏览 1 评论
2107 浏览 1 评论
1978 浏览 5 评论
2852 浏览 3 评论
872浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
639浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
737浏览 0评论
1432浏览 0评论
1121浏览 0评论
GMT+8, 2024-10-14 12:22 , Processed in 1.411624 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
