这已经困扰了我一段时间……随机,并且在任何时候(编辑源或调试)MPLAB停止响应eNITAISE。尝试关闭窗口没有任何效果。任务管理器显示JRE消耗大约50% CPU,没有任何恢复(甚至12小时等待),除非杀死JRE进程和重新启动。我可以在没有问题的情况下运行几天,或者它可以发生几次。对于运行的时间和我做的事情没有明显的模式或相关性——虽然我通常编辑源代码,因为这是我在IDE中的80%的时间。我已经尝试了所有的使用事项(重新启动,删除应用程序和USB驱动程序和重新安装),这与SeMeLa一致。L版本的MPLAB,包括JRE的几种版本。目前在Win 10上运行3.55。
以上来自于百度翻译 以下为原文 This has been annoying me for a while... Randomly, and at any time (editing source or debugging) MPLAB stops responding enitrely. Trying to close the window has no effect. Task manager shows the JRE consuming about 50% CPU and nothing recovers (even a 12-hour wait) except killing the JRE process and restarting. I can go days without an issue or it can happen several times an hour. There is no apparent pattern or correlation to how long it's been running or what I'm doing - although I'm usually editing source since that is about 80% of my time in the IDE. I have tried all the ususal things (reboot, remove app and USB drivers and reinstall), this has been consistent over several versions of MPLAB including several versions of JRE. Currently running 3.55 on Win 10. |
2个回答
选项& gt;嵌入& gt;通用设置& untk“鼠标在编辑器中的源代码行上,评估断点状态”,我假设你正在处理一些繁重的和声项目。看到我的线程相同的问题。HTTP://www. McCHIP.COM/FUMMS/M906161.ASPX
以上来自于百度翻译 以下为原文 options>embedded>generic settings> untick "On mouse over source line in editor, evaluate break point status" I assume you are working on some heavy harmony project. see my thread for same issue. http://www.microchip.com/forums/m906161.aspx |
我经历了完全相同的症状。对于MPLABX的最后N个版本来说,问题一直在我。这是冰冻的总的随机性使我感到困惑。我从未使用过和声。
以上来自于百度翻译 以下为原文 I have experienced the exact same symptoms. The problem has been there for me for the last n versions of MPLABX. It is the total randomness of the freezing that baffles me. And I have never used Harmony. |
只有小组成员才能发言,加入小组>>
5171 浏览 9 评论
2001 浏览 8 评论
1931 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3176 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2228 浏览 5 评论
737浏览 1评论
622浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
509浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
635浏览 0评论
533浏览 0评论
GMT+8, 2024-11-26 03:11 , Processed in 1.176152 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
