电子发烧友论坛|
大家好,如果这是错误的论坛,请道歉,如果有人指向正确的论坛,我将不胜感激。
免责声明:我是VHDL的新手。 我正在寻求为FIR滤波器实现无乘法器的乘法器。 我想尽可能地做到一般,所以我不想硬编码我的组件展示位置。 是否有一种程序生成组件的好方法(即乘数)? 我在CSD中编码了常数被乘数的数字,并将其存储为字符串,我通过'generic'语句将其传递给组件。 现在我试图使用生成循环(循环遍历字符串)来放置加法器,减法器和移位器。 问题是一个加法器/减法器的输出直接输入到下一个输入器的输入端,由于存在未知数量的加法器,我不能事先声明信号。 最好的方法是什么? 以上来自于谷歌翻译 以下为原文 Hi all, apologies if this is the wrong forum for this, it would be much appreciated if someone could point toward the right one. Disclaimer: I'm new to VHDL. I'm looking to implement a multiplier-less multiplier for an FIR filter. I'm trying to be as general as possible, so I don't want to hard-code my component placements. Is there a good method of procedurally generating a component (i.e. a multiplier)? I've encoded the digits of the constant multiplicand in CSD and stored it as string which I'm passing into the component via a 'generic' statement. Now I'm attempting to use a generate loop (looping over the string) to place adders, subtractors, and shifters. The issue is that the output of one adder/subtractor is piped directly into the input of the next one and since there is an unknown amount of adders, I can't declare the signals before hand. What's the best way to go about this? |
2个回答
您可以使用数组声明“通用”数量的信号。
如果每个阶段都有共同的信号,则记录数组会有所帮助。 即: 输入my_signals是记录 i,q:签名(31 downto 0); 结束记录; type my_signal_array是my_signals的数组(自然范围); signal z:my_signal_array(0到GENERIC_VALUE); ..... z(0).I clk,real_in => z(n).i,imag_in = z(n).q,real_out => z(n + 1).I,imag_out => z(n + 1).q ); 结束生成; use_block_B:如果不是use_block_A生成 INST:BLOCK_B(clk => clk,real_in => z(n).i,imag_in = z(n)。q,real_out => z(n + 1).I,imag_out => z(n + 1)。 q); 结束生成; 结束生成; I_out q_out 无论如何,这是个主意。 “z”信号在体系结构中声明(不在生成内部),因此它对生成块是全局的。 以上来自于谷歌翻译 以下为原文 You can declare a "generic" number of signals using arrays. An array of records helps if there are common bundle of signals for each stage. i.e.: type my_signals is record i,q : signed(31 downto 0);end record;type my_signal_array is array(natural range <>) of my_signals;signal z : my_signal_array(0 to GENERIC_VALUE);.....z(0).I <= some_input..;z(0).q <= some_input...; stages : for n in z'range generatebegin use_block_A : if use_block_A generate INST : BLOCK_A ( clk => clk, real_in => z(n).i, imag_in = z(n).q , real_out => z(n+1).I , imag_out => z(n+1).q ); end generate; use_block_B : if not use_block_A generate INST : BLOCK_B ( clk => clk, real_in => z(n).i, imag_in = z(n).q , real_out => z(n+1).I , imag_out => z(n+1).q ); end generate;end generate; I_out <= z(GENERIC_VALUE).I; q_out <= z(GENERIC_VALUE).q; Anyway that's the idea. The "z" signal is declared in the architecture (not inside the generate), so that it is global to the generate blocks. |
只有小组成员才能发言,加入小组>>
3149 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2900 浏览 9 评论
4109 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1363浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1202浏览 1评论
/9
GMT+8, 2025-12-15 17:08 , Processed in 2.615439 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
665
