电子发烧友论坛扫一扫,分享给好友
大家好,我在DDR3规格中发现JEDEC79-3E定义VOH(DC)是DC输出高测量级别(用于IV曲线线性)。
但是没有关于如何测量高输出直流输出的指南,特别是当信号在高电压时有环时,请参见附图。 谁能帮助我测量DDR3的VOH(DC)?谢谢,Huy 以上来自于谷歌翻译 以下为原文 Hi everybody, I found in DDR3 specification JEDEC79-3E define VOH(DC) is DC output high measurement level (for IV curve linearity). But there is no guide for how to measure DC output high, especially when signal has a ring at high voltage level, please see picture attached. Could anyone help me for how to measure VOH(DC) of DDR3? Thanks, Huy 附件
2个回答
简短的回答是为您的示波器购买U7231A DDR3 Compliance SW。
如果您愿意,您还可以获得并使用该SW的免费14天许可证。我们使用的算法摘自该SW的手册:1获取并分割获取信号的读写突发。 找到第一个有效的READ突发.3找到所有有效的正脉冲。 有效正脉冲在有效上升沿的VREF交叉处开始,在随后的有效下降沿处以VREF交叉结束.4放大第一个有效正脉冲并执行VTOP测量。 将VTOP测量结果作为VOH(DC)值.5使用在突发中找到的其余有效正脉冲继续上一步.6确定测量的VOH(DC)组的最差结果。秘密是 找到VTOP,这在“示波器”手册中有所介绍。 我们使用的算法根据信号的形状而变化,我们如何做到这一点是范围内“秘密酱”的一部分.Al 以上来自于谷歌翻译 以下为原文 The short answer is to buy the U7231A DDR3 Compliance SW for your scope. You could also get and use a free 14 day license for that SW, if you wish. The algorithm that we use, excerpted from the manual for that SW is: 1 Acquire and split read and write burst of the acquired signal. 2 Take the first valid READ burst found. 3 Find all valid positive pulses. A valid positive pulse starts at VREF crossing at valid rising edge and ends at VREF crossing at the following valid falling edge. 4 Zoom in on the first valid positive pulse and perform VTOP measurement. Take the VTOP measurement result as VOH(DC) value. 5 Continue the previous step with the rest of the valid positive pulses that were found in the burst. 6 Determine the worst result from the set of VOH(DC) measured. The secret is finding VTOP, which is covered in the Oscilloscope manual. The algorithm that we use changes depending on the shape of the signal, and how we do that is part of the 'secret sauce' in the scope. Al |
nvywyerwer 发表于 2019-4-17 14:15 谢谢Al,知道VTOP是根本用途。 在范围的帮助中有一个衡量VTOP的指南。 非常感谢。 伊 以上来自于谷歌翻译 以下为原文 Thanks Al, It's use-full to know the VTOP is the root. There is a guideline to measure VTOP in scope's help. Thanks very much. Huy |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 08:41 , Processed in 0.603916 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2705
