电子发烧友论坛|
在ASIC设计中,当我们设计百万门SOC时,Cadence和Synopsys的CAD支持经常被要求。
当一个人使用FPGA达到百万当量。 gateignalprocessing算法开发,之后需要购买FPGA,特别是Zynq系列或Altera等效SOC + FPGA,设计PCB板,批量生产产品并通过严格的EMI资格认证。 在什么阶段,公司可能需要将Xilinx称为Altera技术支持? 可能需要什么样的支持? 以上来自于谷歌翻译 以下为原文 In ASIC design, the CAD support from Cadence and Synopsys were often called upon when we design million gate SOC. When one uses FPGA for million equiv. gate signal processing algorithm development, afterwards one needs to purchase the FPGA, specifically Zynq family or Altera equivalent SOC+FPGA, design PCB board, mass produce a product and pass the stringent EMI qualifications. At what stage does the company might need to call Xilinx of Altera tech support? What kind of support might one need? |
7个回答
L,
通常,如果您的设计在没有警告的情况下完成并且受到适当约束,那么它将起作用(几乎可以肯定)。 这就是为什么我们的设备如此受欢迎! 对于woory来说,没有很多变化,并且没有测试逃生装置。 毫无疑问,这两者都是ASIC / ASSP的严重问题。 我们的可靠性是传奇的(ug116),我们返回的故障要么是无,要么在0到3 ppm的范围内很少。 如上所述,有关详细信息,请致电当地的支持 Austin Lesea主要工程师Xilinx San Jose 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 l, Generally, if your design completes with no warnings, and is properly constrained, it will work (almost surely). That is why our devices are so popular! There is no lot to lot variation to woory about, and there is no test escape devices. Both, as you are no doubt aware are serious issues with ASIC/ASSP. Our reliability is legendary (ug116), and our returned failures are either none, or few in the range of 0 to 3 ppm). As above, for details call your local support. Austin Lesea Principal Engineer Xilinx San JoseView solution in original post |
嗨,
这是一个广阔的讨论领域。 请联系最近的销售/分销商以获取详细信息。 请参阅以下链接: http://www.xilinx.com/about/contact/sales-offices.html http://www.xilinx.com/about/contact/authorized-distributors.html 谢谢, 佳日 以上来自于谷歌翻译 以下为原文 Hi, This is vast area of discussion. Please contact nearest Sales/Distributor to get detail information. Refer below links: http://www.xilinx.com/about/contact/sales-offices.html http://www.xilinx.com/about/contact/authorized-distributors.html Thanks, Yash |
嗨@ lis_user1
您需要根据您的设计要求仔细选择设备。 准备好设计要求后, 与您最近的Xilinx销售/分销办事处联系以获取指导。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @lis_user1 You will need to carefully choose the device based on your design requirement. Once you have the design requirements ready, get in touch with your nearest Xilinx sales/distribution office for guidance. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
L,
通常,如果您的设计在没有警告的情况下完成并且受到适当约束,那么它将起作用(几乎可以肯定)。 这就是为什么我们的设备如此受欢迎! 对于woory来说,没有很多变化,并且没有测试逃生装置。 毫无疑问,这两者都是ASIC / ASSP的严重问题。 我们的可靠性是传奇的(ug116),我们返回的故障要么是无,要么在0到3 ppm的范围内很少。 如上所述,有关详细信息,请致电当地的支持 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 l, Generally, if your design completes with no warnings, and is properly constrained, it will work (almost surely). That is why our devices are so popular! There is no lot to lot variation to woory about, and there is no test escape devices. Both, as you are no doubt aware are serious issues with ASIC/ASSP. Our reliability is legendary (ug116), and our returned failures are either none, or few in the range of 0 to 3 ppm). As above, for details call your local support. Austin Lesea Principal Engineer Xilinx San Jose |
谢谢你们。
我并不担心设备的可靠性,而是我们设备选择中X和A的本地存在的重要性。 在我的区域,onehas有一个设计中心,但其他人没有。 如果支持不重要那么我们将更乐意不限制我们的设备选择。 以上来自于谷歌翻译 以下为原文 Thank you all. I am not worrying about the reliability of the device but rather the significance of the local presense of X and A in our device choices. In my district one has a design center but the other doesn't. If support is of little importance then we will be happier not limiting our choices of device. |
L,
老实说,如果您使用千兆位收发器,设计中心是有价值的:如果该中心配备了测试设备,它可能证明是有用的。 当然,您可能已经拥有该设备,或者可以租用它,但您可能没有信号完整性专家,因为配备收发器专家的设计中心可能就是这种情况。 因此,如果您是第一次使用收发器,那么本地中心可能会有优势。 然而,这是一个响应时间的问题,因为我知道Xilinx有专家(就在这里的论坛),所以即使有一个中心,第一个答案在这里答案最快。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 l, Honestly, a design center is of value if you are using the gigabit transceivers: if that center is equipped with the test equipment, it may prove to be useful. Of course, you may have that equipment already, or be able to rent it, but you may not have signal integrity experts close at hand as might be the case with a transceiver expert equipped design center. So, if you are using the transceivers for the first time, there may be an edge with the local center. However, it is a matter of response time, as I know that Xilinx has experts (right here in the forums) so even if there is a center, the first answer is fastest answered right here. Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1198浏览 1评论
/9
GMT+8, 2025-12-14 08:34 , Processed in 1.073314 second(s), Total 83, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2157
