扫一扫,分享给好友
喜
我正在使用xilinx XA2C128 CPLD(在ISE 14.1中编译)。 我已经阅读了数据表,这个cpld有大约80个用户IO。 在这些IO中,有些是GTS =全局输出使能,GSR =全局复位/置位,GCK =全局时钟,CDRST =时钟分频复位等。 我的问题是 - 1)我知道GSR,GCK,GTS引脚可以用作通用IO。 但我想知道其他通用IO是否可以用作CPLD的时钟输入? 或者是否存在一些限制,只有GCK线可用于将时钟输入到CPLD设计中? 2)CPLD中有一个GSR引脚。 shoudl主设计复位输入信号是否特别映射到该引脚,还是可以进入任何通用IO? 3)该cpld(DS554)的数据表显示某些选择IO引脚上有可选的总线保持或弱上拉。 但数据表没有指定引脚。 有人可以说明哪些引脚会有弱p.u.? 请告诉我 ... 谢谢, ž。 以上来自于谷歌翻译 以下为原文 hi, i am working with the xilinx XA2C128 CPLD (compiling in ISE 14.1). i've read the data sheet and this cpld has about 80 user IOs. out of these IOs, some are GTS = global output enable, GSR = global reset/set, GCK =global clock, CDRST = clock divide reset etc. my questions are - 1) i know the GSR, GCK, GTS pins can be used as general purpose IOs. but i wanted to know if the other general purpose IOs can be used as clock input into the CPLD? or is there some restriction that only GCK lines can be used to input clocks into the CPLD design? 2) there is a GSR pin in the CPLD. shoudl the main design reset input signal be mapped to this pin in particular or can it go onto any general purpose IO? 3) the datasheet for this cpld (DS554) says there is optional bus-hold or weak pull-up on some select IO pins. however the datasheet does not specify whcih pins. can someone please shed some light on which pins would have the weak p.u.? please let me know ... thanks, z. |
1个回答
全局时钟,全局输出使能和全局置位/复位CPLD控制信号可以在特殊的全局路由网络(GCK,GTS,GSR)上实现,也可以通过p项实现为普通信号。
分配给全局网络的控制信号更快,不使用功能块资源。 在这里查看更多信息 http://www.xilinx.com/itp/xilinx10/isehelp/ise_r_comp_gck_gts_gsr.htm 对于cpld i / o详细信息,请检查以下哪些内容应该有所帮助 http://www.xilinx.com/support/documentation/user_guides/ug445.pdf 以上来自于谷歌翻译 以下为原文 Global clock, global output enable, and global set/reset CPLD control signals can be implemented either on special globally routed nets (GCK, GTS, GSR) or as ordinary signals through p-terms. Control signals assigned to global nets are faster and do not use function block resources. check for more info on this here http://www.xilinx.com/itp/xilinx10/isehelp/ise_r_comp_gck_gts_gsr.htm for the cpld i/o details check the following which should help http://www.xilinx.com/support/documentation/user_guides/ug445.pdf |
只有小组成员才能发言,加入小组>>
2209 浏览 7 评论
2634 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2111 浏览 9 评论
3184 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2237 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
482浏览 1评论
1563浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2212浏览 0评论
535浏览 0评论
1697浏览 0评论
GMT+8, 2024-6-22 04:33 , Processed in 1.042285 second(s), Total 80, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
