电子发烧友论坛|
实际上我正在使用矢量信号发生器2920和矢量信号分析器2820以及signalmeister软件,我想使用我在matlab中模拟的程序生成单载波信号(PSK),首先我将它转换为IQ导入然后将其转换为arb
文件,然后发送它VSG 2920,我正在调整IQ导入中的采样率,就像我在matlab程序中一样,假设我正在使用脉冲整形滤波器(RRC)和overamling = 5MHZ,所以我调整采样率 在IQ导入到5MHZ,但我有问题。问题是,我没有得到正确的带宽,应该是2 *(1 + alpha / 2 * Ts),我不知道为什么????我猜 我的程序是对的,我在matlab中的propram成功运行,你对这个错误的带宽有什么想法吗?谢谢, 以上来自于谷歌翻译 以下为原文 Actually I'm using Vector signal generator 2920 and Vector signal analyzer 2820 along with signalmeister software, I want to generate single carrier signal (PSK) using my program which I simulate in matlab, first I loade it to IQ import then convert it to arb file then send it VSG 2920,I'm adjusting the sample rate in IQ import as I have in my matlab program ,lets say I'm using pulse shaping filter (RRC) with oversamling=5MHZ,so i'm adjusting the sample rate in IQ import to 5MHZ but I have aproblem. The problem is ,I'm not getting the right bandwidth which supposed to be 2*(1+alpha/2*Ts),I don't know why???? I guess my procedure is right ,and my propram in matlab run succesfully,do you have any idea behind this wrong bandwidth? Thanks, |
1个回答
嗨 - 基于信号的1/5带宽以及您尝试将波形过采样5倍的事实,我建议您查看过采样算法,看看您是否遇到此功能的问题。
问候 - 以上来自于谷歌翻译 以下为原文 Hi - Based upon the 1/5 Bandwidth of your signal and the fact that you are attempting to oversample the waveform by a factor of 5, I would recommend that you look at your oversample algorithm and see if you have an issue with this function. Regards - |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 09:35 , Processed in 0.694523 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1863
