电子发烧友论坛|
您好,我有一个紧迫的项目,我需要交付,我需要论坛成员和微芯片AssiPress解决PICIT3和PIC12F1572之间的错误连接问题。由于皮卡3没有识别/识别这个模型。IsErrad的Web和没有找到任何实际的解决方案,这个问题只是MPLAB解决方案没有相关,因为这是我们如何建立这个SW项目,不知道我们将无法直接连接通过PICtiT3程序员Bur1529 7148!PICIT3和其他PIC一样,像16F5853和其他模型一样伟大,但是当我连接1572,它甚至没有检测到它-我尝试通过手动搜索和切换所有的家庭,我不知道如何解决这个问题-我认为MICCHIPSTeP有解决方案,但没有看到它在网络上。请伸出援助之手。
以上来自于百度翻译 以下为原文 Hello, I have an urgent project I need to deliver and I need the forum members and microchip Assitance to solve the misconnection issue between Picit3 and pic12f1572. As the pickit 3 doesn't recognize/ identify this model. I searched the web and didn't found any practical solution for this issue Only MPLAB solutions which are not relevant because this is how we build this sw project and didn't know we will not be able to connect directly via PICKIT3 PROGRAMMER BUR152974148! The PICIT3 works Great with other pic's like 16f583 and other models but when I connect the 1572 it doesn't even detect it - I tried by manual search and switched all families and I don't know how to solve this issue - I think Microchip team have the solution but didn't saw it on the web. Appreciate In Advance your assistance. |
19个回答
这不是从Microchip获得帮助的最佳场所。你没有清楚地陈述你的问题,所以我怀疑你会从用户那里得到很多帮助。你的“解决方案”是不清楚的。一个皮克特3和MPLabX会跟PICSo说话,你用的是没有MPLab的皮卡3?怎么用?固件的版本是什么?它是怎么到达那里的?它是否足够新来知道如何与新芯片对话?
以上来自于百度翻译 以下为原文 This is not the best place to get help from microchip. You did not clearly state your problem so I doubt you will get much help from users. Your "solution" is un clear. A pickit3 and MPLabX will talk to that PIC So you are using a pickit3 without MPLab? How? What version of firmware is on it? How did it get there? Is it new enough to know how to talk to the newer chip? |
OP可能使用PK3独立应用程序(脚本工具)。@ BARG,也许您可以试试PK2DEVICEFIL.DAT HETPSPS://GITHUB.COM/GBED/……/MST/PICIT2/PK2DFT
以上来自于百度翻译 以下为原文 The OP might use the PK3 standalone application (scripting tool). @barg, maybe you can try the PK2DeviceFile.dat here https://github.com/GBert/.../master/pickit2/pk2dft |
你好,谢谢你的回复。我用PICTIT3作为独立的程序员,PICTIT3版本是BUR15247148,意思是,我把代码上传到应用程序并把它烧到集成电路上。这种编程方式会烧毁16F1933和其他PIC。因为PICIT3版本没有更新,所以我没有找到12F1572的问题,我试图在网络中找到几天,但是找不到,所以我需要一个更新的3版本,可以检测到1572。至于MPLAB,我使用CCS C com。PILER和只使用PICIT3在PIC MCU上导入HEX文件。请建议我在哪里可以找到一个解决方案,如果这不是正确的论坛/地方?因为我不太熟悉这个论坛。
以上来自于百度翻译 以下为原文 Hi, Thank you for your reply. I use the pickit3 as a STAND ALONE PROGRAMMER, the pickit3 version is BUR152974148, meaning, I upload the code to the application and burn it to the ic. this way of programming burn 16f1933 and other pic's. the problem it doesn't detect the 12f1572 because the picit3 version is not updated and I tried to find in the web for a few days and couldn't find so I need an updated version of the pickit 3 that can detect the 1572. As to MPLAB - I use CCS C Compiler And Use only the PICIT3 to import hex file on the pic mcu's. Please advice where can I find a solution if this not the right Forum/place? as I am not oftenly familiar with this forum. Regards |
嗨,Timijk,谢谢你的提议,我检查了你发送的列表,上面显示了PIC12F1572,但是我在哪里找到这个安装到PICTIT3的版本?我有1572和PICIT3会说话吗?
以上来自于百度翻译 以下为原文 Hi Timijk, Thanks for the offer, I checked the list you sent and the pic12f1572 is shown over there but where do I find this version to install to the picit3 i have that the 1572 and picit3 will talk? |
解决方案是用MPLAB将它连接到计算机上,然后选择PIC。它将加载固件到PICTIT3。请注意,它可能不再与其他图片一起工作。固件有几种不同的版本。而每一个都只适合一个家庭图片。它里面的固件只是旧的。
以上来自于百度翻译 以下为原文 The solution is to connect it to a computer with MPLab and select your PIC. It will load the firmware to the pickit3. Note that it may then no longer work with the other PICs. There are several different versions of firmware. And each is only good for a family of PICs. That or the firmware in it is just to old. |
注:我不使用PICTIT3,但ICD3。有任何理由你不更新固件与MPLabX V3.60(我想你需要一个空项目与PIC12F1572)?然后,你可以使用编译器和其他工具与更新的固件。GPEDIT:NK基本上说的是相同的事情。我们交叉邮寄。
以上来自于百度翻译 以下为原文 Note: I don't use the PICKIT3, but the ICD3. Is there any reason you don't update the firmware with MPLabX v3.60 (I think you'll need a null project with the PIC12F1572)? You should then be able to use your compiler and other tools with updated firmware. GP Edit: NK just said essentially the same thing. We cross-posted. |
嗨,格林,代码是在Mikroc写的,我没有考虑与MPLAB一起工作,或者不知道如何把所有东西传送到MPLAB,或者不知道如何用MPLAB烧掉这个准备好的代码。谢谢。
以上来自于百度翻译 以下为原文 Hi Glen, The code was written in Mikroc and i didn't consider to work with MPLAB or don't know how to transfer everything to MPLAB or how to burn this ready code with the MPLAB. Thanks |
在与EXE文件(独立应用程序)相同的文件夹中,应该有一个文件PK2DEVICEFIL.DAT。首先重命名或备份文件,然后从Git项目下载PK2DEVICEFIL.DAT。
以上来自于百度翻译 以下为原文 In the same folder as the exe file (standalone application), there should be a file Pk2DeviceFile.dat. Rename or backup the file first, then download the Pk2DeviceFile.dat from the git project. |
我不是在暗示一个港口。只需获得MPLABX V3.60,创建一个简单的汇编程序项目(源文件中有“结束”),并通过PK3构建并下载它。这将升级皮卡中的固件。他们回到你现在使用的任何工具,它应该工作。
以上来自于百度翻译 以下为原文 I wasn't suggesting a port. Just get MPLabX v3.60, create a simple assembler project (source file with " end" in it), and build and download it via the PK3. That will upgrade the firmware in the PICKIT. They go back to whatever tools you're currently using and it should work. GP |
听起来你使用的是一个独立的程序员软件的最新版本,MPLABX的最新版本将附带IPE的最新版本。
以上来自于百度翻译 以下为原文 sounds like you are using an ancient copy of the standalone programmer software. The latest version of MPLABX will come with the latest version of the IPE. |
我同意QHB。我在MPLAB-X之外进行自动化构建,并使用MPLAB IPE导入HEX文件并对设备进行编程。您可以使用任何想要的生成环境。
以上来自于百度翻译 以下为原文 I agree with qhb. I do automated builds outside of MPLAB-X, and use the MPLAB IPE to import the hex file and program the device. You can use whatever build environment you want. |
安装MPLABX打开IPE应用程序。选择你的图片。选择连接。等待它完成上传。那么你不必和MPLabX一起做一个项目。您不必将项目移动到MPLABX。你只需要它来更新PICTIT3S内部固件。
以上来自于百度翻译 以下为原文 Instal MPLabX Open the IPE application. Select your PIC. Select connect. Wait for it to finish the upload. Then you did not have to make a project with MPLabX. You do not have to move your project to MPLabX. You just need it to update the pickit3s internal firmware. |
你好,NKurzman,非常感谢你的帮助!我试图连接这两个,连接到MPLAB的PICTIT3,但是有一个与定义电源有关的错误,我试图修复它:VIEW POWER设置,但它只是一个信息窗口,你能建议它是什么以及如何修复它吗?
以上来自于百度翻译 以下为原文 Hi NKurzman, Thank you very much for your Assistance! Well, I tried to connect between the two, the pickit3 connected to the mplab but there is an error related to something with defining the power source, I tried to fix that in: VIEW- POWER SETTINGS but it is only an informative window, can you advice what is it and how to fix it? |
我想上传一个屏幕截图,但是服务器不允许这样做,你知道怎么上传图片吗?…
以上来自于百度翻译 以下为原文 I am trying to upload a screenshot but the server doesn't allow to do that, do you know how to upload a picture?... |
如果你是一个新用户,你可能也不能。错误或警告。如果它警告你设置了一个可能损坏的电压,忽略它。你不需要连接到一个芯片。禁用PICTIT3电源电路,警告将消失。一旦你点击连接,看到通知,它是做了更新固件,那么你就完成了。试试你的其他设置。
以上来自于百度翻译 以下为原文 If you are a new user you may not be able too. Error or warning. If it says warning you have set a voltage that may damage something ignore it. You do not need to connect to a chip. Disable Pickit3 powers the circuit and the warning will go away. Once you hit connect and see the notice that it is done updating the firmware, then you are done. Try it with you other setup. |
我尝试了没有IC -只有皮克特连接,但它仍然失败,请找到贝娄输出和设置我使用,也许有什么不对:输出:2017 - 04-23 T20:37:10+ 0300 -完成加载IPE。Cope*************连接失败。右上配置:校验和:45 FE
以上来自于百度翻译 以下为原文 I tried it without the IC - only the PICKIT3 Connected, but it is still failed, please find the bellow output and settings I used, maybe something is wrong: OUTPUT: 2017-04-23T20:37:10+0300- Completed loading IPE. ***************************************************** Connection Failed. ***************************************************** Connection Failed. upper right side configurations: Checksum: 45FE |
我还尝试了独立PICT3应用程序,但它仍然没有检测到1572。
以上来自于百度翻译 以下为原文 I also tried with the independent picit3 application but it still doesn't detect the 1572 |
如果你可以选择列表中的部分,它应该工作。我认为“连接失败”指的是连接到工具(通过USB),而不是工具和芯片之间的连接。这就是它通常会走的路线:
以上来自于百度翻译 以下为原文 If you can select the part in the list, it should work. I think the "connection failed" refers to the connection to the tool (through USB), not the connection between the tool and the chip. Here's how it would normally go: ***************************************************** Connecting to MPLAB ICD 3... Currently loaded firmware on ICD 3 Firmware Suite Version.....01.41.07 |
嗨,NorthGuy,是的,它可以检测到1572,但是它没有改变或者显示它在PICIT3中改变了什么,就像我关闭MPLAB之后,转到PIKIT3独立的应用程序,而它连接到PIC3,它仍然没有检测到IC。(当我把PICIT3连接到MPLAB时,它是没有IC)。请通过USB连接来说明您的意思是什么?如果它检测并启动进程,为什么它在中间停止/失败?你认为连接可能错了吗?谢谢
以上来自于百度翻译 以下为原文 Hi NorthGuy, Yes, it can detect the 1572 but it doesn't change or show that it changes something in the picit3 as after I close the mplab and go to the pikit3 independent app while it connected to the pic3, it is still doesn't detect the ic. (when I connect the picit3 to the mplab, it is without the ic) . Please advice for what you meant for the connection through u*** failed? if it detects and start the process, why it stops/ failed in the middle? do you think maybe the connection is wrong? Thanks |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 03:45 , Processed in 1.522185 second(s), Total 110, Slave 93 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1646
