你好,
我想知道是否有人遇到过此问题,是否可以使用平台电缆USB II通过JTAG编程ARM Cortex M4或任何其他ARM内核? 最好的祝福, 卡洛斯 以上来自于谷歌翻译 以下为原文 Hi there, I am wondering if anybody came across this, is it possible to program an ARM Cortex M4 or any other ARM core via JTAG using the Platform cable USB II? Best regards, Carlos |
2个回答
喜
我假设您指的是连接到我们的Zynq设备上可用的ARM处理器。 如是。 您可以使用作为SDK套件一部分的XMD,使用平台u***-II电缆连接到arm。 请参阅http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Boot+-+Multiboot+Tech+Tip。 命令将是这样的 XMD%连接arm hwXMD%source ps7_init.tclXMD%ps7_initXMD%dow u-boot.elfXMD%con --hem -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 hi, i am assuming that you are referring to connect to ARM processor available on our Zynq devices. if yes. you can use XMD that is a part of SDK suite to connect to arm using a platform u***-II cable. refer to http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Boot+-+Multiboot+Tech+Tip. the commands will be something like this XMD% connect arm hw XMD% source ps7_init.tcl XMD% ps7_init XMD% dow u-boot.elf XMD% con --hem ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
谢谢@htsvn,但非Xilinx器件/ ARM器件呢?
顺便说一句,您共享的链接末尾的点将返回错误页面,以防其他人可能想要引用您的链接: http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Boot+-+Multiboot+Tech+Tip 以上来自于谷歌翻译 以下为原文 Thank you @htsvn, but what about non-Xilinx parts / ARM devices? By the way, the dot at the end of the link you have shared will return an error page, just in case others might want to reference your link: http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Boot+-+Multiboot+Tech+Tip |
只有小组成员才能发言,加入小组>>
2380 浏览 7 评论
2797 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2262 浏览 9 评论
3335 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2428 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
755浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
543浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
365浏览 1评论
1961浏览 0评论
681浏览 0评论
GMT+8, 2024-11-22 13:33 , Processed in 1.421660 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
