嗨,我在电压模式下使用41421B源表单元。
什么是源阻抗(尤其是电抗)? 当我使用力和感应连接时,感应用于校正强制电压。 这如何改变源阻抗? 修正的速度是多少? 这可以用来纠正10 ns的涟漪吗?谢谢,史蒂夫 以上来自于谷歌翻译 以下为原文 Hi, I'm using the 41421B Source Meter Unit in voltage mode. What is the source impedance (especially reactance) ? When I use the force and sense connections, the sense is used to correct the forcing voltage. How does this change the source impedance? What is the speed of the correction? Can this be used to correct 10 ns ripples? Thanks, Steve |
3个回答
嗨,你能检查型号吗?
我在我们的网站上找不到该型号。 以上来自于谷歌翻译 以下为原文 Hi, Can you check on the model number? I cannot find that model number on our website. |
Matt,它是4142B 8插槽SMU主机的旧HP插件。
它已经过时了,但我的问题更为通用,“SMU的源阻抗是多少?”,“力/感应调平环如何影响源阻抗?”谢谢Steve Ortiz 以上来自于谷歌翻译 以下为原文 Matt, It's an old HP plug-in to the 4142B 8 slot SMU mainframe. It's long obsolete, but my questions are more generic, "What is the source impedance of a SMU?", and "How does the force/sense leveling loop affect source impedance?" Thanks, Steve Ortiz |
嗨,SMU的输出阻抗在非开尔文连接时通常为0.2欧姆。通常情况下,DUT和电缆阻抗会增加。如果你使用开尔文连接(4线或力和感应连接),由于阻抗是
非常高,输出阻抗小于0.001欧姆(变得非常小)。最好的问候,中野圭介 以上来自于谷歌翻译 以下为原文 Hi, The output impedance of SMU is typically 0.2ohm at non-kelvin connection. Normally, the DUT and cable impedance will be added. If you use the kelvin connection (4-wire or force and sense connection), since the sence impedance is very high, the output impedance is less than 0.001 ohm (becomes very small). Best regards, Keisuke Nakano |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 01:29 , Processed in 0.893393 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3368
