电子发烧友论坛|
你好,
请有人帮我解决stm8s上的uart问题 我使用14.7456 Mhz的晶体,我也改变了时钟系统,请参阅附加程序。 uart1初始化为,pa4和pa5, 我还使用第二台带有DOCKLIGHT程序的计算机来分析通信。 uart设置为9600波特,1个停止,7个数据甚至奇偶校验 也为此设置了docklight程序。 如果我从stm8s发送一个字符到另一台计算机,我看到该字符是正确的。 即使有不同的角色 不,如果我从另一台计算机上的docklight程序发送一个字符,也会在stm8s数据ram中看到该字符是正确的 但是,如果我将发送一串字符,例如 来自docklight程序的81 82 83 84 85,我在stm8s数据RAM中收到 81 82 03 84 05 我已尝试过其他字符,似乎7位始终设置为1,某些字符是正确的 拜托,有什么想法,我在程序中做错了什么 看到atached汇编程序文件 非常感谢 marc debruyne 以上来自于谷歌翻译 以下为原文 hello, please can someone one help me with a uart problem on the stm8s i use a crystal of 14.7456 Mhz , also i do the change of the clock system, see the atached program. the uart1 is initialised as, pa4 and pa5, also i use a second computer with the DOCKLIGHT program to analyze the communication. the uart is set for 9600 baud, 1 stop , 7 data even parity also the docklight program is set for that . if i send one character from the stm8s to the other computer i see that character correct. even with different characters no if i send a character from the docklight program on the other computeri also see that character correct in the stm8s data ram but if i will send a string of characters ,for example 81 82 83 84 85 from the docklight program,i receive in the stm8s data ram 81 82 03 84 05 i have tryed with other characters, and it seems then the 7 bit is always set to 1, some characters are correct please , is there any idea what i do wrong in the program see atached assembly program file many thanks marc debruyne |
1个回答
由于您已将终端程序配置为7位偶校验,因此您只能使用低7位数据。将调整位7以在发送的数据中提供偶校验。除非您真的需要进行奇偶校验检查,否则如果您为8位无奇偶校验配置BOTH ENDS将会更好。
JDF 以上来自于谷歌翻译 以下为原文 Since you've configured your terminal program for 7 bits Even parity you can only use the lower 7 bits for data. Bit 7 will be adjusted to provide even parity in the transmitted data. Unless you REALLY need parity checking you will be much better off if you config BOTH ENDS for 8 bit no parity. jdf |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 02:54 , Processed in 0.564707 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
416
