电子发烧友论坛|
嗨,我已经在自己的板上使用了我的PICtiT3好几个月了,然后有一天它无法检测设备ID 0x00,尝试另一个PIDIT3,也无法检测ID,试试另一个板,这也行不通。因此,在引脚范围内,MCLR只在5和4V之间切换,另一个CLK和DAT引脚不切换到0V,因此替换了TrimeCIES,并且切换OK,但是仍然看不到设备,替换PIC33 FJ256MC710A,并且再次工作正常。因为我把它们都用在其他的板上了,很好,但是插入了我的可疑板,不能再读取设备ID,不得不替换U8和U9,OK,但是担心这会继续发生,有什么想法能引起这个吗?谢谢!
以上来自于百度翻译 以下为原文 Hi, I've been using my PICKIT3 on my own board for months without issue, then one day it cannot detect device id 0x00, try another PICKIT3 and that too cannot detect ID, try another board and that wont work either. So scoped the pins and saw that on one the MCLR was only switching between 5 and 4V and the other the CLK & DAT pins wheren't switching down to 0v, so replaced the transcievers and was switching ok, but couldn't see device still, replace the PIC33FJ256MC710A and working ok again. Since I've used both of them on other boards, just fine, but plugged into my suspect board and couldn't read device ID again, had to replace U8 & U9, ok again, but fear this is going to keep on happening, any ideas what could be causing this please? Thanks! |
3个回答
高电压或负电压。如果存在接地问题,则可能存在负电压。这包括不正确接地的插座。
以上来自于百度翻译 以下为原文 High or negative voltages. negative can exist if there is a Grounding issue. This includes improperly grounded outlets. |
在假设芯片死掉之前,我将强制更新PK3的固件。断开USB引线,按住PK3按钮,然后将其插入到PC中。然后尝试编程您的芯片,一旦它完成了PK3固件的更新。
以上来自于百度翻译 以下为原文 I'd force a firmware update of the PK3 before assuming the chips are dead. Disconnect the USB lead, hold down the PK3 button, and plug it back into your PC. Then try programming your chip, once it has completed updating the PK3 firmware. |
我们大学有70个皮卡3,从来没有真正的硬件问题。几个星期前,我从别人那里得到了一个PK3,他说它不再工作了。检查信号PGD,PGC…在程序中没有任何内容。(我在收发器的内部和外部用独立的PICTIT3软件检查了信号)最后,我不得不更换U8,9和11,因为所有的都被吹了。在其中一个可以很容易地看到神奇的烟雾已经离开了包。一个显而易见的是让烟从底部排出;
以上来自于百度翻译 以下为原文 We have >70 PICkit3 at our university and never any had really a hardware problem. Some weeks ago I got one PK3 from someone else who said it is not working anymore. Checked the signals PGD, PGC... with scope and there was nothing during programming. (I checked the signals with standalone PICkit3 software at the transceiver ins and outs) In the end I had to replace U8,9 and 11 because all have been blown. At one of them one could easily see that the magic smoke already left the package. A second one obviously let the smoke out at the bottom side ;-) |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-1 22:35 , Processed in 0.656461 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2951
