电子发烧友论坛|
我有一个项目使用APIC32 MX170F512H50I/PT(64针通用PIC32 MX)。SPI1工作良好。但是我不能让SPI2工作。我已经尝试了许多不同的方式打开外围设备,但引脚仍然分配给GPIO,没有时钟出现。具体来说,我正在寻找一个时钟在引脚4(AN16/C1NI/RPG6/SCK2/PMA5/RG6根据数据表)。没有提到SPI问题的勘误表。我将非常感谢您的SU。格言。
以上来自于百度翻译 以下为原文 I have a project using a PIC32MX170F512H-50I/PT (64 pin general purpose PIC32MX). SPI1 is working fine. However I simply cannot get SPI2 to work. I've tried many different ways of turning on the peripheral, but the pins remain allocated to GPIO, no clock emerges etc. Specifically I'm looking for a clock on pin 4 (AN16/C1IND/RPG6/SCK2/PMA5/RG6 according to the data sheet). No mention of SPI problems in the errata. I would be grateful for your suggestions. |
3个回答
比较器(C1IN)在默认情况下可能出现,可能会超过它。您尝试过:CM1CONClR=(1和lt;lt;15);/ /确保比较器是OffANSELGCl= =(1和lt;lt;6);/ /确保PIN是数字的,否则您可能需要实际共享一些代码以获得更多帮助。
以上来自于百度翻译 以下为原文 The comparator (C1IND) appears possibly be on by default which may override it. Have you tried: CM1CONCLR = (1<<15); //make sure comparator is off ANSELGCLR = (1<<6); //make sure pin is digital Otherwise you may need to actually share some of your code for more help. |
虽然我在PIC32 MX470F512L上使用SPI2,但它具有相同的PIN功能。我所做的是:ANSELGBITS.ANSG6=0;//DigialTrasgGbs.TrISG6=0;//SCK2作为配置和启用SPI2控制寄存器之前的输出。
以上来自于百度翻译 以下为原文 Although, I use SPI2 on the PIC32MX470F512L fine, and it has the same pin functions. All I do is: ANSELGbits.ANSG6 = 0; //Digital TRISGbits.TRISG6 = 0; //SCK2 as output before configuring and enabling the SPI2 control registers. |
很难说这是我代码中的一个愚蠢的错误。SPI2外围设备在打开和使用之间被关闭。很抱歉浪费了每个人的时间。
以上来自于百度翻译 以下为原文 Embarrassed to say this was a stupid bug in my code. The SPI2 peripheral was being turned off between being turned on and used. Sorry for wasting everybody's time. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:24 , Processed in 0.914019 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1463
