电子发烧友论坛|
大家好,
我想知道位文件和ucf文件有什么区别? 最好的祝福, 比拉尔 以上来自于谷歌翻译 以下为原文 Hi all, I am wondering what is the difference between bit file and ucf file? Best regards, Bilal |
4个回答
@bilalqureshi这个回答你的问题?
如果是,请通过标记帖子帮助您作为答案来关闭主题。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @bilalqureshi Does this answer your question? If yes please close the thread by marking the post helped you as answer.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution.View solution in original post |
嗨,UCF(用户约束文件)是给FPGA实现工具的指令,用于指导实现工具在处理FPGA设计时遵循的映射,布局,时序或其他指导。位文件包含正确所需的所有信息
配置由设计实现工具创建的设备。 已经记录了各个FPGA系列的比特流的一般格式化以支持部分重配置,但是没有记录各个位。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, UCF (User Constraint File) are instructions given to the FPGA implementation tools to direct the mapping, placement, timing or other guidelines for the implementation tools to follow while processing an FPGA design. The bit file contains all of the information necessary to properly configure the device that was created by the implemenation tools for your design. The general formating of the bitstream for individual FPGA families has been documented to support partial reconfiguration, but the individual bits are not documented.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨,
bit是实现工具的输出。 ucf是一个输入,用于指导实现工具根据时序要求放置和路由设计。 -hem -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 Hi, bit is the output of implementation tools. ucf is an input that guides implementation tools to place and route the design as per the timing requirements. -hem ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
如果是,请通过标记帖子帮助您作为答案来关闭主题。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 @bilalqureshi Does this answer your question? If yes please close the thread by marking the post helped you as answer.Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 19:21 , Processed in 0.731185 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2268
