电子发烧友论坛扫一扫,分享给好友
先生,
我正在做两个复数的乘法,而不是我想要计算答案的绝对值,这是我工作的一部分。 我已经成功地完成了两个复数的乘法,现在有了定点库的帮助我想要计算答案的绝对值: 所以我想要答案的平方根[(real(CN)* real(CN)-imag(CN)* imag(CN))],其中CN是乘法后的复数,当我使用sqrt函数时它会给出以下错误 错误:HDLCompiler:69-“C: Users Hcl Desktop 123 pc1 delete delete.vhd”第36行:未声明。 错误:HDLCompiler:622-“C: Users Hcl Desktop 123 pc1 delete delete.vhd”第36行:靠近sfixed; 类型转换表达式类型不能唯一确定 错误:HDLCompiler:854-“C: Users Hcl Desktop 123 pc1 delete delete.vhd”第15行:由于先前的错误而忽略了单位。 先生,请说明我如何进一步行动。 非常感谢。 以上来自于谷歌翻译 以下为原文 Sir, I am doing the multiplication of the two complex number than I want to calculate the absolute value of the answer it is one of the part of my work. I have successfully done till multiplication of two complex number with the help of fixed point library now I want to calculate the absolute value of answer : So I want the square root of the answer [(real(CN)*real(CN) –imag(CN)*imag(CN))], where CN is Complex Number after multiplication when I use the sqrt function it gives the following error ERROR:HDLCompiler:69 - "C:UsersHclDesktop123pc1deletedelete.vhd" Line 36: ERROR:HDLCompiler:622 - "C:UsersHclDesktop123pc1deletedelete.vhd" Line 36: Near sfixed ; type conversion expression type cannot be determined uniquely ERROR:HDLCompiler:854 - "C:UsersHclDesktop123pc1deletedelete.vhd" Line 15: Unit Sir, please give the path how I can proceed further. Thanks a lot. |
4个回答
你可以附上你的代码。
是模拟还是综合中的这个问题。 您在设计中使用的流程,即Vivado,vivado HLS,ISE 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 you can attached your code. Is this issue in simulation or in synthesis . which flow you are using in your design i.e. Vivado , vivado HLS, ISEThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
sunil7写道:
先生,请说明我如何进一步行动。 对于初学者,请向我们展示您的代码,格式正确。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 sunil7 wrote:For starters, show us your code, properly formatted. ----------------------------Yes, I do this for a living. |
请发给我这个问题的测试用例。
如果未定义库,则可能会出错。 您的代码可能不包含SQRT函数的定义。 您用于SQRT功能的核心。 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 please send me test case for this issue. The error may come if library is not defined . Your code may not contain definition of SQRT function. which core you are using for SQRT function.Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
在VHDL中,没有预定义的平方根操作。
您可以自己编写该函数或从网上获取该函数,或使用Xilinx IP为您实现该函数。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 In VHDL there is no predefined square root operation. You can write the function yourself or obtain one from the net or use a Xilinx IP to implement it for you. - Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
只有小组成员才能发言,加入小组>>
3123 浏览 7 评论
3412 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2877 浏览 9 评论
3971 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3062 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1337浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1177浏览 1评论
/9
GMT+8, 2025-12-4 11:11 , Processed in 0.796163 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2492
