电子发烧友论坛|
嗨,大家好
我正在尝试在Ubunto上运行Xilinx EDK,在阅读了很多主题后,我做了这个脚本: -------------------------------------------------- ----- #!/斌/庆典 cd /opt/Xilinx/12.3/ISE_DS/ISEsource settings32.shcd /opt/Xilinx/12.3/ISE_DS/EDKsource settings32.sh cd /opt/Xilinx/12.3/ISE_DS/EDK/bin/lin./xps -------------------------------------------------- --- 我的问题是,当我运行此脚本时,没有任何错误,没有错误,但xps没有打开 另一方面,我有其他的scirpt运行ise工作完美。 以上来自于谷歌翻译 以下为原文 Hi everyone I am trying to run Xilinx EDK on Ubunto, after reading a lot of topics, i did this script: ------------------------------------------------------- #!/bin/bash cd /opt/Xilinx/12.3/ISE_DS/ISE source settings32.sh cd /opt/Xilinx/12.3/ISE_DS/EDK source settings32.sh cd /opt/Xilinx/12.3/ISE_DS/EDK/bin/lin ./xps ----------------------------------------------------- my problems is that when i run this script nothing ocurred, no errors, but xps is not opened in other hand, i have other scirpt to run ise that work perfectly. |
1个回答
嗨,
检查这个帖子:http://forums.xilinx.com/t5/Installation-and-Lensingensing/ISE-12-1-on-Linux-Ubuntu-EDK-does-not-start/td-p/73616 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, check this thread: http://forums.xilinx.com/t5/Installation-and-Licensing/ISE-12-1-on-Linux-Ubuntu-EDK-does-not-start/td-p/73616 Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 20:23 , Processed in 0.588902 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
972
