电子发烧友论坛|
我目前不得不在两个版本的vee之间切换,因为我没有时间在vee 8中重写vee 5程序。有没有办法直接将vee 5程序导入vee 8并且它们仍然可以工作?我试过了
在vee 8中运行其中一个程序并且它出现了错误信息并且刚刚关闭,所以我猜它不那么直接,但有没有办法做到这一点而不必重写所有的程序?谢谢 提前。也许值得注意的是,我是一个非常新的人,所以我可能只是在做一些愚蠢的事情并且过于复杂的事情,但任何建议都会非常感激。 以上来自于谷歌翻译 以下为原文 hi i am currently having to keep switching between two versions of vee because i do not have time to rewrite the vee 5 programs in vee 8. is there a way of directly importing the vee 5 programs into vee 8 and them still work? i tried just running one of the programs in vee 8 and it came up with error messages and just closed down, so im guessing its not as straight forward as that, but is there a way of doing it without having to rewrite all of the programs? thanks in advance. also might be worth noting that i am very new to vee so i may just be doing something stupid and over complicating things but any advice would be greatly appreciated. |
2个回答
通常它会运行良好。
在VEE 8中,您可能希望将默认首选项中的执行模式更改为VEE 5以进行尝试。 以上来自于谷歌翻译 以下为原文 Usually it will run well. In VEE 8, you may want to change the execution mode in Default Preferences to VEE 5 to try out. |
它可以帮助您快速阅读每个新版本的发行说明。
这可能会给你一些线索并帮助你缩小你所拥有的错误类型。我知道一个困扰我现在工作的程序涉及布尔变量。 类型布尔值是VEE 8的新增功能,但if / then / else和其他表达式始终存在这个概念。 但是type Boolean有两个值,true和false。 其他表达式有1和0.如果你想要“1”得到“真”,你可能会遇到问题。 由于我没有亲自看过这个,我只是告诉你我被告知了什么......所以仔细权衡上述经验,祝你好运! 以上来自于谷歌翻译 以下为原文 It may help you to quickly read the release notes for each new version. That may give you a clue and help you narrow down the types of errors you have. I know one that plagued programs where I work now involved Boolean variables. Type Boolean is new to VEE 8 but the concept always existed for if/then/else and other expressions. But type Boolean has two values, true and false. The other expressions had 1 and 0. If you get "true" where you wanted "1", you may have a problem. Since I have not personally seen this, I am only telling you what I have been told...... so weigh the above experience carefully, and good luck! |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1843浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 17:54 , Processed in 0.633269 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1392
