电子发烧友论坛|
你好,我需要一些帮助来设置另一个设置在我的USB设备描述符,通过Windows徽标工具包所需的所有测试,最后证明我的设备和驱动程序。
此刻我正在进行一些初步的测试使用USB命令验证器(u***20cv)版本r1.4.2.5从www.u***.org但描述测试失败,错误如下:*******接口数量:0,交替设置:0、端点号:2,maxpacketsize:40备用设置0非零maxpacketsize -同步端点带宽检查失败(1.2.40)在交互界面0x00同步端点现在必须有一个maxpacketsize的0x00 ******* 所以我试图创建两个交替设置(0,1),第一个“交替设置为“数据包大小为Isoch终点等于零,但没有成功。我也试着去创造“备用设置0“没有-同步端点也是本案没有成功。 每一次我试图说明在descr.a51交替设置文件的设备失灵与VID = 0x0000和PID = 0x0000引导。 谁能解释一下我如何设置一个备用设置里面的描述符,并最终通过USB命令验证试验? 谢谢埃曼纽尔 我的原始DISCR.A51文件对消息进行了攻击。 DCSC.A51.TXT.ZIP 1.5 K 以上来自于百度翻译 以下为原文 Hello, I need some help in order to setup an alternate setting inside my u*** device descriptor in order to pass all test required by the Windows Logo Kit and finally to certify my device and driver. At the moment I'm performing some preliminary test using the USB Command Verifier (USB20CV) version R1.4.2.5 from www.u***.org but the descriptor test fails with the following error: ******* Interface Number : 0, Alternate Setting : 0, Endpoint Number : 2, MaxPacketSize : 40 Alternate setting 0 has non zero MaxPacketSize Isoch endpoint Bandwidth check failed (1.2.40) An Isochronous endpoint present in alternate interface 0x00 must have a MaxPacketSize of 0x00 ******* So I tried to create two alternate setting (0 and 1), the first one "alternate setting 0" with a packet size for the Isoch endpoint equal to zero but without success. I also tried to create the "alternate setting 0" without the Isoch endpoint but also in this case without success. Every time I try to specify an alternate setting inside the descr.a51 file the device fails and boot with the VID=0x0000 and PID=0x0000. Can someone please explain me how to setup an alternate setting inside the descriptor and how eventually to pass the USB Command Verifier test ? Thanks Emanuele P.S. My original descr.a51 file is attched to the message.
1个回答
最后,我找到了让备用设置工作和USB CV测试通过的方法!!
我得到了一些更多的信息来阅读这个文档//www. CyPress。docid = 23736and看相关固件里面包http://www.cypress.com/?RID=34870。 拜伊 艾玛 以上来自于百度翻译 以下为原文 Finally I found the way to make the alternate settings working and USB CV test pass I got some more information reading this document http://www.cypress.com/?docID=23736 and looking at the related firmware available inside this package http://www.cypress.com/?rID=34870 . Bye Ema |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7572浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6118浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7965浏览 2评论
/9
GMT+8, 2025-12-2 17:20 , Processed in 0.588046 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1561
