电子发烧友论坛|
嗨,我正在尝试使用simulink将正弦信号的绝对值发送到daq卡并将其连接到DSO3062A示波器以查看我是否正在发送正确的信号。
matlab显示我正在正确发送信号,它是一个在0和1之间振荡的绝对正弦波,但是示波器显示它在-0.5和0.5伏之间振荡,这是不可能的,因为我发送信号的绝对值。 即使我发送信号的绝对值,该设备是否始终将其参考点保持为零? 谢谢你的帮助。 以上来自于谷歌翻译 以下为原文 Hi, I am trying to send the absolute of a sine signal to the daq card using simulink and connected it to the DSO3062A oscilloscope to see if I am sending the right signal. Matlab shows that I am sending the signal correctly, it is an absolute sine wave oscillating between 0 and 1 but oscilloscope shows that it is oscillating between -0.5 and 0.5 volts which should not be possible since I am sending the absolute of the signal. Is this device keep its reference point always at zero even if I send the absolute of the signal? Thanks for your help. |
1个回答
您可能处于交流耦合模式,它会阻止信号的直流分量,使其以0为中心。我不知道如何更改它,但我确定它在通道设置中。
人 以上来自于谷歌翻译 以下为原文 You are probably in AC coupling mode, which blocks the DC components of a signal, causing it to center on 0. I don't know how to change it, but I'm sure it's in the channel settings. Al |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:34 , Processed in 0.760576 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1088
