嗨,我正在使用VISA命令(python接口,PyVisa)从示波器(MSO6xxx和MSO7xxxx系列)获取波形数据。
我们正在观察以下问题:a)捕获后如何观察数据。 我们非常依赖高分辨率采集,然而,似乎范围是在正常采集模式下返回测量数据,并且该数据不适合执行我们的自动测试评估。 有没有人以前遇到过这个问题? 有关更多信息,请参阅以下代码:captureParameters + =“:ACQUIRE:TYPE%s;” %(acquireType) - >设置为“HRESOLUtiON”captureParameters + =“COMPLETE 100”+ writeData(captureParameters)+ waitIfBusy()+ timeBaseParameters =“:TIMEBASE:MODE MAIN;”+ writeData(timeBaseParameters)+ #Setting Waveform format + waveCaptureParameters = “”waveCaptureParameters + =“:WAVEFORM:SOURCE CHANNEL%i;” %(channel)waveCaptureParameters + =“:WAVEFORM:UNSigned 0;” waveCaptureParameters + =“:WAVEFORM:FORMAT BYTE;” waveCaptureParameters + =“:WAVEFORM:BYTeorder LSBF;” waveCaptureParameters + =“:WAVEFORM:POINTS:MODE MAX;” waveCaptureParameters + =“:WAVEFORM:POINTS%i”%(points) - >通常1000000 writeData(waveCaptureParameters)askData(“:WAVEFORM:DATA?”) 以上来自于谷歌翻译 以下为原文 Hi, I am acquiring waveform data from scope (MSO6xxx and MSO7xxxx families) using VISA commands (python interface, PyVisa). We are observing the following problems: a)How the data is observed after capture. We rely a lot on High Resolution acquisition, however, it seems the scope is returning the measured data in NORMAL acquistion mode, and that data is not suitable for performing our automatic test evaluation. Does anyone have had this problem before? For more information, here is the code I am using: captureParameters += ":ACQUIRE:TYPE %s;" % (acquireType) -> set to "HRESOLUTION" captureParameters += "COMPLETE 100"+ writeData(captureParameters)+ waitIfBusy()+ timeBaseParameters = ":TIMEBASE:MODE MAIN;"+ writeData(timeBaseParameters)+ #Setting Waveform format+ waveCaptureParameters = "" waveCaptureParameters += ":WAVEFORM:SOURCE CHANNEL%i;" % (channel) waveCaptureParameters += ":WAVEFORM:UNSigned 0;" waveCaptureParameters += ":WAVEFORM:FORMAT BYTE;" waveCaptureParameters += ":WAVEFORM:BYTeorder LSBF;" waveCaptureParameters += ":WAVEFORM:POINTS:MODE MAX;" waveCaptureParameters += ":WAVEFORM:POINTS %i" % (points) -> Usually 1000000 writeData(waveCaptureParameters) askData(":WAVEFORM:DATA?") |
1个回答
我也试过“:DIGitize”,但结果是一样的。
任何人都面临这个问题吗? 以上来自于谷歌翻译 以下为原文 I also tried ":DIGitize" but results are the same. Anyone facing this problem, also? |
只有小组成员才能发言,加入小组>>
1229 浏览 0 评论
2350 浏览 1 评论
2160 浏览 1 评论
2026 浏览 5 评论
2908 浏览 3 评论
973浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
706浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
807浏览 0评论
1229浏览 0评论
GMT+8, 2024-11-25 10:57 , Processed in 1.661419 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
