我最近在我的DSO-X 2022A上安装了MSO升级版,它为我提供了8个额外的数字输入。
在尝试按照Agilent InfiniiVision 2000 X系列示波器程序员指南(例如,第502页)设置SPI MOSI源时,似乎代码中必定存在错误,因为MSO似乎没有完全激活 (在安装MSO许可证并证明数字输入有效之后,设备已经重新启动)。 上面的命令语法描述为:SBUS:SPI:SOURce:MOSI :: = {CHANnel | EXTernal}用于DSO模型:: = {CHANnel | DIGital}用于MSO模型:: = 1到(#模拟通道)NR1格式:: = 0到(#数字通道 - 1)NR1格式当尝试使用USBTMC接口将以下命令发送到示波器时, 它尖叫着回到我身边“参数错误”:: SBUS:SPI:SOURce:MOSI DIGital0这是MSO设备上的预期结果吗? 此致,尼克拉斯 以上来自于谷歌翻译 以下为原文 I have recently installed the MSO upgrade to my DSO-X 2022A, which gives me eight extra digital inputs. While trying to follow the Agilent InfiniiVision 2000 X-Series Oscilloscopes Programmer's Guide on, for example page 502 for setting the SPI MOSI source, it seems like there must be a bug in the code somewhere, because the MSO does not seem to be fully activated (the unit has been power cycled after the MSO license was installed and the digital inputs are proven to work). The command syntax on the above page is described as :SBUS:SPI:SOURce:MOSI ::= {CHANnel | EXTernal} for the DSO models ::= {CHANnel | DIGital} for the MSO models ::= 1 to (# analog channels) in NR1 format ::= 0 to (# digital channels - 1) in NR1 format When trying to send the following command to the oscilloscope using the USBTMC-interface, it screams back at me "Parameter error": :SBUS:SPI:SOURce:MOSI DIGital0 Is this an expected outcome on an MSO device? Regards, Nicklas |
1个回答
是的,3000-X系列可同时提供串行解码和MSO,数字通道可用作串行触发和解码源。 2000-X系列的限制是由于MegaZoom ASIC中的共享处理模块可用于数字通道或串行解码。 3000-X系列中的附加ASIC允许我们同时使用这两种功能。 以上来自于谷歌翻译 以下为原文 Yes, serial decode and MSO are available simultaneously on the 3000-X series and digital channels may be used as serial trigger and decode sources. The limitation in the 2000-X series is due to a shared processing block in the MegaZoom ASIC that may be used either for digital channels or serial decoding. The additional ASIC in the 3000-X series allows us to use both features simultaneously. |
只有小组成员才能发言,加入小组>>
1063 浏览 0 评论
2302 浏览 1 评论
2089 浏览 1 评论
1963 浏览 5 评论
2834 浏览 3 评论
832浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
613浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
709浏览 0评论
1392浏览 0评论
1065浏览 0评论
GMT+8, 2024-9-28 06:29 , Processed in 1.171436 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
