我们正面临从SD启动的问题,我们放置了使用SDK创建的BOOT.bin,仅包含f***l.elf(不包括u-boot.elf),当我们尝试在zc706上从SD启动它时,我们得到以下内容
日志: Xilinx第一阶段引导加载程序版本2013.4 Jan 2014-17-17:42:58Devcfg驱动程序初始化Silicon Version 1.0Boot模式为SDSD:rc = 0SD:无法打开文件BOOT.BIN:3 SD_INIT_FAILFSBL状态= 0xA009此引导模式不支持FallbackIn F***lHookFallback函数 请帮我们解决这个问题... 问候 Shabbir 以上来自于谷歌翻译 以下为原文 We are facing the problem with booting from SD, we placed BOOT.bin created using SDK with only f***l.elf (no u-boot.elf included) included, and when we try to boot it from SD on zc706 we are getting the following log: Xilinx First Stage Boot Loader Release 2013.4 Jan 4 2014-17:42:58 Devcfg driver initialized Silicon Version 1.0 Boot mode is SD SD: rc= 0 SD: Unable to open file BOOT.BIN: 3 SD_INIT_FAIL FSBL Status = 0xA009 This Boot Mode Doesn't Support Fallback In F***lHookFallback function Please help us in fixing this issue... Regards Shabbir |
4个回答
请查看此处的讨论:http://forums.xilinx.com/t5/Embedded-Linux/Can-not-boot-Zynq-from-SD-or-QSPI/m-p/280616/highlight/true#M5361
以上来自于谷歌翻译 以下为原文 Please check the discussion here: http://forums.xilinx.com/t5/Embedded-Linux/Can-not-boot-Zynq-from-SD-or-QSPI/m-p/280616/highlight/true#M5361 |
我提到了上面的链接,但对我没有运气,我没有找到合适的解决方案
以上来自于谷歌翻译 以下为原文 I referred the above link, but no luck for me, i didn't find appropriate solution |
我也有这个问题。
但在消息“SD:无法打开文件BOOT.BIN:3”之前Zynq输出“没有SD卡存在”。 检测卡状态时,mmc.c源的disk_initialize()函数发生错误。 当SD卡插入时,SD控制器的寄存器“Present_State”包含0x1F20000值,必须等于0x1F30000。 此外,我成功地从我的主板上的SD卡运行Linux(我从这里获得了发布图像)。 因此,SD卡和板必须工作。 哪里可以出错? 以上来自于谷歌翻译 以下为原文 I have this problem too. But before message "SD: Unable to open file BOOT.BIN: 3" Zynq output "No SD card present." Error occur in disk_initialize() function of mmc.c source, when detect card state. Register "Present_State" of SD controller contain 0x1F20000 value, which must be equal 0x1F30000, when SD card inserted. Also, I successful run Linux from this SD card on my board (I got release image from here). consequently, SD card and board must work. Where can be error? |
我解决了我的问题。
我尝试在我的zc706主板上移植xapp1079示例项目。 为此,我从xapp1079打开XPS项目,并在项目设置中替换XC7Z045上的XC7Z020。 我将硬件项目导出到SDK后。 但是我在这个SDK工作区中创建的FSBL运行不正确。 当我为zc706创建新的XPS项目时,将其导出到SDK并制作新的FSBL,SD卡的问题就消失了。 以上来自于谷歌翻译 以下为原文 I solve my problem. I tryed porting xapp1079 example project on my zc706 board. For that I open XPS project from xapp1079 and replace XC7Z020 on XC7Z045 in project settings. After I export the hardware project to SDK. But FSBL, which I make in this SDK workspace, run incorrect. When I create new XPS project for zc706, export it to SDK and make new FSBL, the problem with SD card disappear. |
只有小组成员才能发言,加入小组>>
2321 浏览 7 评论
2729 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2368 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
652浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
460浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
220浏览 1评论
667浏览 0评论
1859浏览 0评论
GMT+8, 2024-9-29 00:44 , Processed in 1.334697 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
