#include
#define uchar unsigned char #define dula P0 #define wela P2 ***it k4=P3^6; ***it k5=P3^7; ***it beep=P2^3; bit stop=1; unsigned char j,k,num0,num1,num2,num3,sec,min,count=0; unsigned time_count; unsigned char code weitable []={0x8f,0x4f,0x2f,0x1f}; unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef}; void delay(unsigned char i) { for(j=i;j>0;j--) for(k=125;k>0;k--); } void display1(char wei,uchar shu) { wei=wei-1; wela|=0xf0; if(wei==2) P0=table1[shu]; else P0=table[shu]; wela=wela&weitable[wei]; delay(5); } void diaplay(unsigned char a,unsigned char b,unsigned char c,unsigned char d) { display1(4,a); display1(3,b); display1(2,c); display1(1,d); } void start_timer() { EA=1; ET0=1; TR0=1; } void stop_timer() { EA=0; ET0=0; TR0=0; } void main() { TMOD=0x01; TH0=0X4c; TL0=0X00; while(1) { if(k4==0) { delay(10); if(k4==0) { while(k4==0); { if(stop) start_timer(); else stop_timer(); stop=~stop; P1=0xff; beep=1; } } } else if(k5==0) { delay(10); if(k5==0) { while(k5==0); { stop_timer(); stop=1; count=0; time_count=0; sec=0; min=0; P1=0xff; beep=1; } } } if(stop) { count++; if(count==100) { P1=~P1; count=0; } } else if(time_count==20) { count=0; time_count=0; sec++; if(sec==60) { sec=0; min++; } if(min==60) { min=0; } beep=0; delay(10); beep=1; } num0=sec%10; num1=sec/10; num2=min%10; num3=min/10; display (num3,num2,num1,num0); } } void timer0()interrupt 1 { TH0=0x4c; TL0=0x00; time_count++; } |
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
有人有STM8H1K08T连接TM1650的源码吗,可以直接使用的那种,我的代码在烧录之后数码管一直处于熄灭状态
271 浏览 0 评论
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
493 浏览 0 评论
589 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
891 浏览 0 评论
1436 浏览 2 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16926 浏览 31 评论
/9
GMT+8, 2025-12-4 10:18 , Processed in 0.871545 second(s), Total 86, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5609
