电子发烧友论坛|
刚买回来的华美A100路由器,马上想刷一下固件试一试摄像头功能,可为什么根据视频一样的方法就是刷不进去呢? 步骤跟视频一样,但是最后是出现TTTTT字样不是....字样,就是刷不进去。
11个回答
如果其他步骤都无误。检查是否网线没插好。或者换条网线
我想了解下具体的连线方式。操作流程是按视频上来的, 但是视频中只是说用tftp下载,能否用画板详细画出连线方式。还有tftp的设置,为什么我这边下载就是不行呢,出现TTTT字样,视频中就可以用
关 360试试
电脑没有安装360,金山毒霸也退出了,一样不行。同样的我用tftp刷mini2440的内核、文件系统等都没有问题,下面是在华美A100上刷固件时候串口的提示信息
U-Boot 1.1.8 (Mar 13 2012 - 16:24:24) Board: Ralink APSoC DRAM: 32 MB relocate_code Pointer at: 81fb0000 ****************************** Software System Reset Occurred ****************************** spi_wait_nsec: 42 spi device id: ef 40 17 0 0 (40170000) find flash: W25Q64BV raspi_read: from:30000 len:1000 .*** Warning - bad CRC, using default environment ============================================ Ralink UBoot Version: 3.6.0.0 -------------------------------------------- ASIC 5350_MP (Port5<->None) DRAM_CONF_FROM: Boot-Strapping DRAM_TYPE: SDRAM DRAM_SIZE: 256 Mbits DRAM_WIDTH: 16 bits DRAM_TOTAL_WIDTH: 16 bits TOTAL_MEMORY_SIZE: 32 MBytes Flash component: SPI Flash Date:Mar 13 2012 Time:16:24:24 ============================================ icache: sets:256, ways:4, linesz:32 ,total:32768 dcache: sets:128, ways:4, linesz:32 ,total:16384 ##### The CPU freq = 360 MHZ #### estimate memory size =32 Mbytes raspi_read: from:40028 len:6 . raspi_read: from:0 len:30004 ....[ff ff] Init Plat A1 *************Is_update = 0 plat = 1************** No lcd plat Disable u*** U*** ok Please choose the operation: 1: Load system code to SDRAM via TFTP. 2: Load system code then write to Flash via TFTP. 3: Boot system code via Flash (default). 4: Entr boot command line interface. 7: Load Boot Loader code then write to Flash via Serial. 9: Load Boot Loader code then write to Flash via TFTP. 1 You choosed 1 0 1: System Load Linux to SDRAM via TFTP. Please Input new ones /or Ctrl-C to discard Input device IP (192.168.1.109) ==:192.168.1.109 U-Boot 1.1.8 (Mar 13 2012 - 16:24:24) Board: Ralink APSoC DRAM: 32 MB relocate_code Pointer at: 81fb0000 spi_wait_nsec: 42 spi device id: ef 40 17 0 0 (40170000) find flash: W25Q64BV raspi_read: from:30000 len:1000 .*** Warning - bad CRC, using default environment ============================================ Ralink UBoot Version: 3.6.0.0 -------------------------------------------- ASIC 5350_MP (Port5<->None) DRAM_CONF_FROM: Boot-Strapping DRAM_TYPE: SDRAM DRAM_SIZE: 256 Mbits DRAM_WIDTH: 16 bits DRAM_TOTAL_WIDTH: 16 bits TOTAL_MEMORY_SIZE: 32 MBytes Flash component: SPI Flash Date:Mar 13 2012 Time:16:24:24 ============================================ icache: sets:256, ways:4, linesz:32 ,total:32768 dcache: sets:128, ways:4, linesz:32 ,total:16384 ##### The CPU freq = 360 MHZ #### estimate memory size =32 Mbytes raspi_read: from:40028 len:6 . raspi_read: from:0 len:30004 ....[ff ff] Init Plat A1 *************Is_update = 0 plat = 1************** No lcd plat Disable u*** U*** ok Please choose the operation: 1: Load system code to SDRAM via TFTP. 2: Load system code then write to Flash via TFTP. 3: Boot system code via Flash (default). 4: Entr boot command line interface. 7: Load Boot Loader code then write to Flash via Serial. 9: Load Boot Loader code then write to Flash via TFTP. You choosed 1 0 1: System Load Linux to SDRAM via TFTP. Please Input new ones /or Ctrl-C to discard Input device IP (192.168.1.109) ==:192.168.1.157 Input server IP (192.168.1.55) ==:192.168.1.114 Input Linux Kernel filename () ==:flash_100ask_IP_Camera_debug_V1.0.4.bin netboot_common, argc= 3 NetTxPacket = 0x81FE5E40 KSEG1ADDR(NetTxPacket) = 0xA1FE5E40 NetLoop,call eth_halt ! NetLoop,call eth_init ! Trying Eth0 (10/100-M) Waitting for RX_DMA_BUSY status Start... done Header Payload scatter function is Disable !! ETH_STATE_ACTIVE!! Using Eth0 (10/100-M) device TFTP from server 192.168.1.114; our IP address is 192.168.1.157 Filename 'flash_100ask_IP_Camera_debug_V1.0.4.bin'. TIMEOUT_COUNT=10,Load address: 0x80800000 Loading: * ArpTimeoutCheck T T T T T T T T T T Retry count exceeded; starting again Trying Eth0 (10/100-M) ETH_STATE_ACTIVE!! ArpTimeoutCheck ArpTimeoutCheck Using Eth0 (10/100-M) device TFTP from server 192.168.1.114; our IP address is 192.168.1.157 Filename 'flash_100ask_IP_Camera_debug_V1.0.4.bin'. TIMEOUT_COUNT=10,Load address: 0x80800000 Loading: * ArpTimeoutCheck T T T T T T T T T T Retry count exceeded; starting again Trying Eth0 (10/100-M) ETH_STATE_ACTIVE!! ArpTimeoutCheck ArpTimeoutCheck Using Eth0 (10/100-M) device TFTP from server 192.168.1.114; our IP address is 192.168.1.157 Filename 'flash_100ask_IP_Camera_debug_V1.0.4.bin'. TIMEOUT_COUNT=10,Load address: 0x80800000 Loading: * ArpTimeoutCheck T T T T T T T T T T Retry count exceeded; starting again Trying Eth0 (10/100-M) ETH_STATE_ACTIVE!! ArpTimeoutCheck ArpTimeoutCheck Using Eth0 (10/100-M) device TFTP from server 192.168.1.114; our IP address is 192.168.1.157 Filename 'flash_100ask_IP_Camera_debug_V1.0.4.bin'. TIMEOUT_COUNT=10,Load address: 0x80800000 Loading: * ArpTimeoutCheck T T T T |
换根网线呢
你先看能否print
请问你解决了吗?我遇到了和你一样的问题!
没解决,还是很难下载,偶尔成功
1. 你先测试是不是网络环境问题
只有小组成员才能发言,加入小组>>
296个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2473 浏览 6 评论
2209 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4837 浏览 1 评论
/9
GMT+8, 2025-12-18 01:57 , Processed in 0.766369 second(s), Total 84, Slave 74 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2017
