扫一扫,分享给好友
`j-link刷固件报错用sam-ba v2.12软件刷j-link的固件为什么报error h_handle returned zero错误!求解决办法`
3个回答
我也遇到这情况了,哪位大神帮忙解答一下吧
搜到一篇帖子,说是因为使用了USB3.0的端口造成的。
Sam-Ba v2.12 -> Error h_handle returned zero [Win7] Wed Sep 18, 2013 11:38 am Hello My Sam-Ba show up message after startup window(where it picks up communication port and board): Image Error h_handle returned zero while executing "TCL_Open $target(connection)" invoked from within "if {$::argc >= 2}{ puts "-I- Retrieved arguments from command line:" puts "-I- argv 0 : [lindex $::argv0]" puts "-I- argv 1 : [linde..." (file "C:/Program Files(x86)/Atmel/sam-ba_2.12/sam-ba.exe/lib/tkcon.tcl" line 4924) invoked from within "source [file join $startkit::topdir lib/tkcon.tcl]" (x86)/Atmel/sam-ba_2.12/SAM-BA.exe/main.tcl" line 6) The main window not show up, however, the Sam-Ba process is still present in the task manager (0 percent activity). Not any patches don't help, it is still the same. How can I fix it? St starir Posts: 13 Joined: Wed Aug 21, 2013 11:05 am Post Re: Sam-Ba v2.12 -> Error h_handle returned zero [Win7] Tue Sep 24, 2013 8:05 am Hello, I founded this experimental points during work with SAM-BA, may be help you. 1- SAM-BA don't work with USB3 port in this version 2.12, I had the same problem with you and found that this problem is because of using USB3 port. 2- if you encountered any problem during work with SAM-Ba, first of all close SAM-BA software and end task it from task manager and next disconnect your board from USB port of PC 3- if you programmed your board with JTAG before using SAM-BA, first of all erase the chip with the JTAG and next make high "erase" pin, but if you can't use JTAG again, you must first make erase pin high and then make TST pin high (for SAM7X, may be vary in other parts) to copy the bootloader to flash. 4- the time for making erase pin high state is <10s according datasheet, but I found that this time is about 30 second and for TST pin is about 60 second. 5- Newly I found that the current rating of power supply also can make errors for SAM-BA. If current of Power Supply be not enough, so will make errors during Erase and TST high steps and then USB port give USB not Recognized Error. if you disconnect the board from USB port before the required time or has mistakes in required steps, the PC give "USB device not recognized" error. I hope this help you. Regards. 没办法验证…… |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
811 浏览 0 评论
525 浏览 0 评论
嵌入式学习-搭建自己的ubuntu系统之ubuntu网络设置
646 浏览 0 评论
龙芯中科胡伟武:3B6600 八核桌面 CPU 性能将达到英特尔中高端酷睿 12~13 代水平
710 浏览 0 评论
树莓派Pico 2发布,搭载RP2350双核RISC-V和Arm Cortex-M33微控制器!
670 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
10722 浏览 31 评论
GMT+8, 2024-8-17 22:15 , Processed in 0.542685 second(s), Total 77, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
