我今天正在实现FIFO,我想知道FIFOPrimitive和Block RAM实现之间的区别是什么。
根据我的理解,它们使用相同的底层RAM原语,但FIFOPrimitive不能有不同的R / W方面或双时钟域。 除了向导中列出的明显限制外,还有哪些其他差异? FIFOPrimitive在Block RAM上有什么优势? 为了记录,我正在使用6系列Virtex,但这适用于任何具有我认为的FIFOPrimitive的家庭。 提前感谢您的想法! 以上来自于谷歌翻译 以下为原文 I was implementing a FIFO today and I was wondering what the difference between the FIFO Primitive and the Block RAM implementations are. From what I can understand, they use the same underlying RAM primitives, but the FIFO Primitive can't have different R/W aspects or dual clock domains. Other than the obvious limitations which are outlined in the wizard, what are the other differences? What advantage does the FIFO Primitive give you over the Block RAM? For the record, I'm using 6-series Virtex, but this would apply to any family that has the FIFO Primitive I would think. Thanks in advance for your thoughts! |
1个回答
V6在FPGA的块ram中包含一些FIFO逻辑。
如果已经使用块ram并且符合FIFO原语的功能,这应该减少实现FIFO所需的资源。 请参阅ug363第43页的概述: http://www.xilinx.com/support/documentation/user_guides/ug363.pdf 虽然我已经使用了fifo原语,但我没有花时间用coregen的通用块ram fifo来实现它,并比较实现资源,如果你这样做,请在这里发布你的结果:)。 以上来自于谷歌翻译 以下为原文 V6 includes some FIFO logic in the block ram of the FPGA. This should reduce the resources needed to implement a FIFO if it is already using a block ram and fits the capabilities of the FIFO primitive. See the overview on page 43 of ug363 : http://www.xilinx.com/support/documentation/user_guides/ug363.pdf Although I have used the fifo primitive I have not taken the time to implement the same with a generic block ram fifo from coregen and compare the implementation resources, if you do so please post your results here :). |
只有小组成员才能发言,加入小组>>
2175 浏览 7 评论
2613 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2082 浏览 9 评论
3153 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2201 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
437浏览 1评论
1533浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2182浏览 0评论
512浏览 0评论
1653浏览 0评论
GMT+8, 2024-5-6 00:26 , Processed in 1.417997 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
