电子发烧友论坛|
嗨,我刚刚从推荐消息下载并安装了MPLABX V3.65,它显示了IDE的一些改进。相反,我不能从PigIT 3电源选项应用电源,因为它们是灰色的。不仅在权力选择,而且在所有其他选择。需要做什么?
以上来自于百度翻译 以下为原文 Hi, I just downloaded and installed MPLABX v3.65 from the recommendation message that shows up thinking some improvement in ide was made. Instead I cannot apply power from PICKIT 3 power option because they are grayed out. Not only in the power option but also in all other options. what needs to be done? Attached Image(s) |
2个回答
检查你已经选择了一个PIC32处理器(在CONF:CART)中,以匹配你所拥有的XC32工具链。或者为你所使用的微控制器添加合适的工具链。
以上来自于百度翻译 以下为原文 Check that you've got a PIC32 processor selected (in the Conf: section) to match the XC32 toolchain you've got there. Or add the right toolchain for the microcontroller you're using. Dom. |
嗨,DOM,谢谢你的提示,但我刚刚解决了问题,重新启动PC做了(我想),并上传也成功地与3.65.1,但你所说的X32工具链也是一些困扰。我注意到输出-配置加载错误窗口显示:信息:配置“默认”将在“C:程序文件Microchip xC32 v1.43bin”中用工具链“XC32”构建。并且在编译后(编译成功)时,我看到MPLABX抱怨X32。我不确定它是什么……但是构建成功了,程序加载到Micro也是成功的。我在看这一点,不能在这一点上抱怨。谢谢。
以上来自于百度翻译 以下为原文 hi dom, thanks for your tip but i just solved the problem, restarting the PC did it (i think), and uploaded also successfully first with 3.65. but what you say about x32 toolchain is also something that is also bothering. I notice the Output- Configuration Loading Error window shows: info: Configuration "default" will build with toolchain "XC32" at "C:Program FilesMicrochipxc32v1.43bin". and also when or after compiling(Build Succeeded) i saw MPLABX complaining about X32. i am not sure what is it .......but the build is successfully and program loading into micro is also successful. i am watching this and cannot complain at this point. thanks |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:44 , Processed in 0.784969 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2350
