好的,我看到一些非常奇怪(令人沮丧)的东西。MPLABX 3.65不再显示输出窗口中的任何东西。它似乎悬在那里很长一段时间。它也不再是我的目标了。我用它已经好几个星期了。它工作得很好。突然间,它就停止工作了。我以为这是我正在做的项目,但我试过其他项目,他们也做同样的事情。我试着在V3.60中打开和编译了一个相同的项目(我在升级到3.6之后安装了)。所以,我卸载了V3.65并重新安装了3.65,我也遇到了同样的问题。为什么这些工具易受失败影响?注意,我正在使用XC32网络许可证,服务器正在运行。有人知道这会不会导致输出窗口完全退出什么问题?在购买网络许可证之前,我试图设置优化级别,我会在输出窗口中得到警告。
以上来自于百度翻译 以下为原文 OK, I am seeing something very strange (and frustrating). MPLABX 3.65 no longer shows anything in the output window. It just seems to hang there for a very long time. It no longer programs my target either. I have been using it with no problems for weeks. It was working fine. All of a sudden it just quit working. I thought it was the project I was working on, but I have tried other projects and they do the same thing. AND I tried opened and compiled the same project(s) in v3.60 (which I left installed after upgrading to 3.6.5). So, I uninstalled v3.65 and re-installed 3.65 and I have the same problems. Why are these tools so vulnerable to failure? Note that I am using XC32 network license and the server is up and running. Does anyone know if there could be a problem with that that would cause the output window to quit anything at all? Before I purchased the network license and I tried to set optimization levels, I would get warnings in the output window. |
7个回答
尝试窗口-gt;重置窗口。尝试在重新安装之前清除缓存文件夹。
以上来自于百度翻译 以下为原文 Try Window -> Reset Windows. Try Clearing the Cache Folders before reinstalling. |
感谢NKZZMAN的回复。重新设置窗口不起作用。当我点击图标“制作和编程设备主项目”时,它会一直保持灰色,直到我关闭MPLABX并重新打开它为止。你能解释一下我需要在重新安装之前清理缓存文件夹吗?
以上来自于百度翻译 以下为原文 Thanks for the response NKurzman. Resetting the Windows didn't work. When I click the icon to "Make and Program Device Main Project", it just stays gray and doesn't come out of it until I close MPLABX and reopen it. Can you explain where I need to Clean the Cache Folders before reinstalling? |
嗨,你的电脑最近有什么变化吗?一些用户报告了MalButhBox的更新问题,在将其添加到异常列表MPLAB X之后,它又工作了。几个月后,NVIDIA更新也创造了一些问题。NVIDIA发布了一个补丁后不久,解决这个问题。您可能想尝试这些不同的程序:1 /点手动MPLAB在您的编译器所在。这可能是因为你有一个网络版本,MPLAB X没有自动检测它:工具& GT;选项& gt;“构建工具”按钮& Gt;Add Button & Gt;…2,清理目录:http://MyCHIPPrdult/COM/MPLABX:持久性数据表
以上来自于百度翻译 以下为原文 Hi, Was there any change on your computer recently ? Some users reported than an update to Malwarebytes created issues. After adding it to the exception list MPLAB X, it worked again. Few months back, an nVidia update also created some issues. nVidia issued a patch shortly after to solve the issue. you may want to try these various procedures : 1/ point manually MPLAB where your compiler is located. It could be that because you have a network version, MPLAB X does not detect it automatically : Tools > Options > "Build tools" button > add button > ..... 2/ Clean the directories : http://microchipdeveloper.com/mplabx:persistence-data Regards |
RISC,清除你在第2节中提供的链接中解释的持久性数据就行了。谢谢!
以上来自于百度翻译 以下为原文 RISC, Cleaning out the persistence data explained in the link you provided in #2 did the trick. Thanks! |
精彩,你能在你的标题中加上[解决]吗?谢谢
以上来自于百度翻译 以下为原文 Brilliant, Can you please add [SOLVED] to your thread title ? thanks |
只有小组成员才能发言,加入小组>>
5238 浏览 9 评论
2028 浏览 8 评论
1950 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3204 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2253 浏览 5 评论
776浏览 1评论
665浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
594浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
675浏览 0评论
575浏览 0评论
GMT+8, 2024-12-22 23:36 , Processed in 1.258579 second(s), Total 91, Slave 74 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
