你好,
我写了一个简单的程序来测试BLE通知。 这将每隔2秒更新一个计数器。 约20~24秒后,连接丢失。 我附上了我的代码,如果有人可以看一下,告诉我哪里出错了。 亲切的问候, 达米安 ByrEngul. Cyrkk.Asvivi01.Zip 862 K 以上来自于百度翻译 以下为原文 Hi, I've written a simple program to test the BLE notifications. This will update a counter every 2 seconds. After about 20-24 seconds with connection is lost. I've attached my code, if someone could have a look and tell me where i'm going wrong. kind regard, Damian
4个回答
嗨,达米安,
请让我们知道你在先锋套件或自定义板项目的测试? 你检查过UART的断开原因了吗? 谢谢,Anjana 以上来自于百度翻译 以下为原文 Hi Damian, Could you please let us know whether you are testing the project on pioneer kit or custom board? Have you checked the Disconnect reason on UART? Thanks, Anjana |
嗨,Anjana,
我正在使用CY8KIT-042 BLE和022001个EVALPPLIN板 在UART上,最后一个事件代码是40个十进制,以前的是66。 当做, 达米安 以上来自于百度翻译 以下为原文 Hi Anjana, i am using the CY8kit-042 BLE with the 022001-EVAL plugin board on the uart the last event code is 40 decimal and previous to that is 66. regards, damian |
我在我的系统里没有看到你的问题。我按下复位按钮和绿色广告绿色LED亮,然后我打开我的手机,我cysmart得到65然后39然后一个消息,说装置间隙连接然后一个事件代码42我没有经验,出来的时候你看到。现在它已经在超过2分钟的蓝色LED上。
以上来自于百度翻译 以下为原文 Daman_Aus Well I am not seeing your issue on my system. I Press the reset button and the Green Advertising green led comes on and then I open CySmart on my Phone and I get a 65 and then a 39 then a message that says Device Gap Connected then an Event code of 42 I didn't experience the time out you saw. Right now it has been on for over 2 minutes and the Blue led is on. |
嗨,鲍勃,
谢谢你的反馈。 在CyScript中,您是否按压通知按钮开始接收通知?我发现一旦按下这个按钮,就会出现超时。我假设这会发送一个我没有响应的写请求。 我添加了代码来响应它,现在它工作得很好。 最初,我认为已经启用通知,因为这是我如何在组件配置文件中设置CCDCD.显然不是这样的。 谢谢你的帮助,我很感激。 当做, 达米安 以上来自于百度翻译 以下为原文 Hi bobgoar, thanks for your feedback. In CySmart, were you presssing the notify button to start receiving the notifications? I've found that the timeout would occur once i pressed this button. I'm assuming that this sends a write request that i wasn't responding to. I've added code to respond to it, and now it works fine. originally i thought notifications would already be enabled as that is how i set it up the CCCD in the component profile. Apparently that's not how it works. thanks for your time, i appreciate it. regards, Damian |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1909 浏览 1 评论
1662 浏览 1 评论
3418 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1579 浏览 6 评论
1387 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
205浏览 2评论
193浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
334浏览 2评论
361浏览 1评论
71浏览 1评论
GMT+8, 2024-5-7 21:20 , Processed in 0.795998 second(s), Total 85, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
