电子发烧友论坛|
嗨,
我正在从两个LIS3DH中读取数据。所有工作都按预期工作,直到满刻度设置为+ -16g。 根据数据手册,当FS为11且启用低功耗模式时,数据输出寄存器中的每个LSb代表192mg。低功耗模式在OUT_X / Y / Z_H寄存器中提供8位输出。 8位2的补码数的最大值是127,因此数据输出寄存器理论上可以显示127 * 192mg = 24g。这超过了+ -16g的阈值。这是否意味着在低功耗模式和+ -16g满量程中,数据输出寄存器中的数字永远不会超过16000mg / 192mg = 83?我从数据输出寄存器中获取127和-128等值,这对我来说没有意义。 我相信我的寄存器配置是正确的,因为当加速度计平放在地面上时我能够读取(0,0,5)。考虑到有限的分辨率,5 * 192mg = 960mg,足够接近1g。 问候, 凯文S. 以上来自于谷歌翻译 以下为原文 Hi, I am reading data out from two LIS3DHs. All works as expected until the full scale is set to +-16g. According to the data sheet, when FS is 11 and low power mode is enabled, each LSb in the data output registers represent 192mg. Low-power mode gives a 8 bit output in the OUT_X/Y/Z_H registers. The maximum value of a 8 bit 2's complement number is 127, and thus the data output registers can in theory show 127*192mg = 24g. This exceeds the +-16g threshold. Does this mean that in low-power mode and +-16g full scale, the number in the data output registers can never exceed 16000mg / 192mg = 83? I am getting values such as 127 and -128 from the data output registers, which don't make sense to me. I believe my register configurations are correct, as I was able to read (0, 0, 5) when the accelerometer is placed flat on the ground. 5*192mg = 960mg, which is close enough to 1g considering the limited resolution. Regards, Kevin S |
3个回答
加速度计的功能保证高达+ -16g。
如果加速度较高,您可以读取超过16g但不保证精度,线性度和整体性能。 以上来自于谷歌翻译 以下为原文 The functionality of the accelerometer is guaranteed up to +-16g. In case the acceleration is higher you can read more than 16g but the accuracy, linearity and overall performance is not guaranteed. |
嗨,
谢谢你的快速反应。只是确保我理解正确,加速度计的数据输出不会在+ -16g处切断,但可以更高。但是,+ -16g以外的任何数据都不能保证准确。我的理解是否正确? 谢谢, 凯文S. 以上来自于谷歌翻译 以下为原文 Hi, Thank you for the quick response. Just making sure I understand correctly, the accelerometer's data output does not cutoff at +-16g, but can go up higher. However any data outside of +-16g is not guaranteed to be accurate. Is my understanding correct? Thank you, Kevin S |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1472 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1526 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3674 浏览 1 评论
3864 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2483 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
753浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
685浏览 5评论
730浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
977浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
781浏览 5评论
/9
GMT+8, 2025-12-15 11:32 , Processed in 0.772988 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1838
