扫一扫,分享给好友
您好,我正在设计一个GSG共面电路。
我在输入和输出端有焊盘用于接地信号接地连接。 我还有一个用于电源 - 接地电源配置偏置的焊盘。 我还有内部端口,用于连接FET和电容器等设备,用于EM协同仿真。 我过去曾经使用过ADS 2009,但我不确定如何在新的ADS 2013中为这种共面设计设置端口。 如果有人能解释如何设置和校准这3种连接类型(GSG,PGP和内部),我将非常感激。 编辑:我应该提一下,我正在使用微波动量进行模拟。编辑:kippodan于2013年12月1日下午7:59 以上来自于谷歌翻译 以下为原文 Hello, I'm designing a GSG coplanar circuit. I have pads at the input and output for ground-signal-ground connections. I also have pads for biasing in a power-ground-power configuration. And I also have internal ports for connections to devices such as FETs and capacitors for an EM co-simulation. I've used ADS 2009 a little bit in the past but I'm unsure how to setup ports in the new ADS 2013 for this kind of coplanar design. If someone could explain how to setup and calibrate these 3 connection types (GSG, PGP and internal) I would be very grateful. edit: I should mention that I'm using microwave momentum for the simulation. Edited by: kippodan on Dec 1, 2013 7:59 PM |
1个回答
我发现了如何设置端口 - 以防有人发现自己和我在同一条船上。
要设置与端口P1(信号),P2和P3(gnd)的G-S-G连接,请转到端口编辑器并展开P1,P2和P3部分。 每个端口都有一个'+'和' - '终端,在这种情况下' - '是gnd。 将P2'+'端子拖放到P1' - '端子,并对P3执行相同的操作。 然后P2和P3应显示在P1端口的“ - ”端子中。 要设置内部端口,请将校准设置为无。 以上来自于谷歌翻译 以下为原文 I found out how to set up the ports - in case anyone find themselves in the same boat as me. To set up a G-S-G connection with ports P1 (signal), P2 and P3 (gnd) go to the port editor and expand the P1, P2, and P3 sections. Each port has a '+' and '-' terminal, in this case '-' is gnd. Drag and drop the P2 '+' terminal into the P1 '-' terminal, and do the same for P3. P2 and P3 should then show up in the '-' terminal of the P1 port. To set up internal ports set calibration to none. |
只有小组成员才能发言,加入小组>>
956 浏览 0 评论
2242 浏览 1 评论
2022 浏览 1 评论
1893 浏览 5 评论
2762 浏览 3 评论
745浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
541浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
633浏览 0评论
2422浏览 0评论
1474浏览 0评论
GMT+8, 2024-9-1 07:45 , Processed in 1.361148 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
