使用STM32FCUBEMX V4.20生成工程.使用STM32F030R8T6仿真tiM1 的四路pwm没有波形,甚至运行不了。其他的TIM3的四路正常和TIM15的二路也正常。
添加的程序为pwm启动指令和pwm的占空比设置指令: HAL_TIM_PWM_Start(&htim1,TIM_CHANNEL_3); HAL_TIM_PWM_Start(&htim1,TIM_CHANNEL_1); HAL_TIM_PWM_Start(&htim1,TIM_CHANNEL_2); HAL_TIM_PWM_Start(&htim1,TIM_CHANNEL_4); __HAL_TIM_SET_COMPARE(&htim1,TIM_CHANNEL_1,40); __HAL_TIM_SET_COMPARE(&htim1,TIM_CHANNEL_2,80); __HAL_TIM_SET_COMPARE(&htim1,TIM_CHANNEL_3,120); __HAL_TIM_SET_COMPARE(&htim1,TIM_CHANNEL_4,190); TIM1的设置程序(cube生成): /* TIM1 init function */ static void MX_TIM1_Init(void) { TIM_ClockConfigTypeDef sClockSourceConfig; TIM_MasterConfigTypeDef sMasterConfig; TIM_OC_InitTypeDef sConfigOC; TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig; htim1.Instance = TIM1; htim1.Init.Prescaler = 24; htim1.Init.CounterMode = TIM_COUNTERMODE_UP; htim1.Init.Period = 200; htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; htim1.Init.RepetitionCounter = 0; htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE; if (HAL_TIM_Base_Init(&htim1) != HAL_OK) { Error_Handler(); } sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK) { Error_Handler(); } if (HAL_TIM_PWM_Init(&htim1) != HAL_OK) { Error_Handler(); } sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK) { Error_Handler(); } sConfigOC.OCMode = TIM_OCMODE_PWM1; sConfigOC.Pulse = 0; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET; sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET; if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK) { Error_Handler(); } if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_2) != HAL_OK) { Error_Handler(); } if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_3) != HAL_OK) { Error_Handler(); } if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_4) != HAL_OK) { Error_Handler(); } sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE; sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE; sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF; sBreakDeadTimeConfig.DeadTime = 0; sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE; sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH; sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE; if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK) { Error_Handler(); } HAL_TIM_MspPostInit(&htim1); } |
11个回答
自己顶起来。
跟踪看看是不是死在等待时钟源了。
我之前也是产生不了,你试试检查一下,是不是没有开启时钟和使能之类的指令
4.20版本有问题啊,如果没修改代码会直接进HardFault,升级到4.21试试!!
跑死在哪一段程序了?单步仿真看看
是不是死在等待时钟源了。
L496的HAL库中官方例程用的就是TIM1输出4路PWM。楼主可以参考一下。
好像STM32F0 没有STM32F030R8T6,只有C8T6。
我的也没有波形,
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32CUBEMX(5)--自定义红外NEC解码,定时器TIM捕获方式
85 浏览 0 评论
stm32f407vet6+LAN8720A调试以太网遇到软件复位失败问题
418 浏览 0 评论
使用STM32CubeMX对红外波形进行GPIO输出,并LED显示
348 浏览 0 评论
404 浏览 0 评论
1021 浏览 1 评论
GMT+8, 2024-9-5 21:22 , Processed in 1.240888 second(s), Total 92, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
