电子发烧友论坛|
正在为回损做校准。
从73.5Ghz开始停止在8.2Ghz输出功率为0 db Cal d up没有故障。 我从午餐回来,现在我正在阅读“无法解读”。 它在-20dbm处再次平稳。 有人以前看过这个问题吗? 我检查了DUT上的输出以确保我没有用电压击中它并且没有任何存在。 任何帮助将不胜感激! 巴尔多 以上来自于谷歌翻译 以下为原文 Was doing a calibration for return loss. Start at 73.5Ghz Stop at 8.2Ghz Output pwr at 0 db Cal d up without a hitch. I come back from lunch and I'm getting a "unleveled" reading now. It levels out again at -20dbm. Anyone see this problem before? I checked my output on the DUT to ensure I did not hit it with voltage and there is none present. Any help would be greatly appreciated! Bardo |
2个回答
嗨Bardo - 这听起来像硬件故障。
这是一个相当大的力量下降。 完成故障排除源的整个过程将是漫长的,但我首先要比较每个频段的最大水平功率。 然后我会回过头来测量射频链的功率。 造成这种损失的最典型原因是不良的倍频器或模拟放大器。 我希望这有帮助 - 以上来自于谷歌翻译 以下为原文 Hi Bardo - It sounds like a hardware failure. That’s a fairly large drop in power. It would be lengthy to go through the entire process of troubleshooting sources, but I would start by comparing maximum leveled power in each band. Then I would just work back through the RF chain measuring power. The most typical causes for this kind of loss would be a bad doubler or mod amp. I hope this helps - |
在雅培先生提到的范围之外,有几个因素可能导致失败。
如果您需要维修,可以联系安捷伦罗斯维尔工厂的Dan Allen。 dan_allen@agilent.com提及我已将信息转发给您。 他可以帮助您修理此乐器。 以上来自于谷歌翻译 以下为原文 There are several components that can cause the failure outside of what Mr. Abbott mentioned. If you need it repaired you can contact Dan Allen at Agilent's Roseville facility. dan_allen@agilent.com Mention I forwarded the information to you. He can assist you with the repair of this instrument. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 01:07 , Processed in 0.672451 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8456
