您好,我正面临着一些MSO6054A示波器的连接问题。
使用Agilent Connection Expert(16.3.17218.1)。 我有一个完全正常工作的范围(连接正常,我可以发送和接收答案,例如* IDN?命令)和2无法正常工作。 我得到的错误是“!VI_ERROR_RSRC_NFOUND:找不到匹配的资源/不再匹配Visa ErrorCode:0xBFFF0011(-1073807343)”。 所有示波器都连接到同一网络。 改变网络电缆不是问题的机会,良好的范围仍然是好的,坏的仍然是坏的。 示波器上的所有设置都相同,这意味着启用了LAN。 启用DHCP,AutoIP,动态DNS和Netbios。 VISA地址是“TCPIP0 :: 10.196.6.140 :: inst0 :: INSTR”。 什么是坏的是Web服务器。 这似乎没有受到影响。 此外,使用安捷伦连接专家,添加仪器,它只能自动找到好的仪器。 在我看到它们之前,我必须手动添加坏的IP地址。 希望有人可以帮助我。 thx Koen 以上来自于谷歌翻译 以下为原文 Hello, I am facing a connection issue with some of my MSO6054A scopes. Using Agilent Connection Expert (16.3.17218.1). I have one scope which is perfectly working (connection is ok and i can send and receive answer on for example the *IDN? command) and 2 which are not working. The error I get is " ! VI_ERROR_RSRC_NFOUND: No matching resources found / no more matches Visa ErrorCode: 0xBFFF0011 (-1073807343) ". All of the scopes are connected to the same network. Changing the network cable does not chance the issue, the good scope remains good, the bad ones remain bad. All of the settings on the scopes are identical, meaning LAN enabled. DHCP, AutoIP, Dynamic DNS and Netbios enabled. The VISA address is "TCPIP0::10.196.6.140::inst0::INSTR". What is working on the bad ones is the web server. This seems to be not affected. Also, using the Agilent connection expert, add instrument, it only finds the good one automatically. I have to manually add the ip-address of the bad ones before I can see them. Hope someone can help me out here. thx Koen |
3个回答
如果关闭好的会发生什么?
它们都在同一个子网上吗? 你说有1个好,2个坏。 所有的IP地址是什么? 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 What happens if you turn off the good one? Are they all on the same subnet? You said there is 1 good and 2 bad. What are all of the IP addresses? Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
你好,如果我关掉那个好的那个,那么坏的一个还是坏的。 它们都在同一个子网上。 使用viFind应用程序,它找到所有这些:此应用程序使用的是32位Agilent VISA + Found 4资源:+ +1:TCPIP0 :: 10.196.6.126 :: inst0 :: INSTR + +2:TCPIP0 :: 10.196.6.140 :: inst0 :: INSTR + +3:TCPIP0 :: 10.196.6.151 :: inst0 :: INSTR +(好一个)+4:PXI0 :: MEMACC + + Done + +按退出+问候,koen 以上来自于谷歌翻译 以下为原文 Hello, If I turn off the good one then the bad ones remain bad. They are all on the same subnet. Using the viFind application, it finds all of them: This application is using 32-bit Agilent VISA +Found 4 resources:+ +1: TCPIP0::10.196.6.126::inst0::INSTR+ +2: TCPIP0::10.196.6.140::inst0::INSTR+ +3: TCPIP0::10.196.6.151::inst0::INSTR+ (good one) +4: PXI0::MEMACC+ +Done+ +Press to exit+ regards, koen |
MAZHILEI 发表于 2019-1-28 08:23 是时候与您当地的技术呼叫中心取得联系了。 人 以上来自于谷歌翻译 以下为原文 It's time for you to get in touch with your local Technical Call Center. Al |
只有小组成员才能发言,加入小组>>
1175 浏览 0 评论
2329 浏览 1 评论
2125 浏览 1 评论
1998 浏览 5 评论
2874 浏览 3 评论
906浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
673浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
770浏览 0评论
1176浏览 0评论
GMT+8, 2024-10-31 21:18 , Processed in 1.207583 second(s), Total 52, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
