电子发烧友论坛|
大家好,
我使用的PSoC Designer 5.1在Windows笔记本电脑,当我把我的代码我得到以下信息: “C:柏 psocde ~ 1. 5.1 普通该~三工具”:中断/异常捕获(代码= 0xc0000005,地址= 0x776f2262) 有没有人知道怎么处理这个错误?我以前从未有过这样的事。 迈克 以上来自于百度翻译 以下为原文 Hi everybody, I'm using de Psoc Designer 5.1 on a Windows 7 laptop and when i build my code i get the following message: "C:CypressPSOCDE~15.1CommonCYPRES~3toolsmake": Interrupt/Exception caught (code = 0xc0000005, addr = 0x776f2262) Does anybody know what to to with this error? I never had something like this in the past. Mike |
7个回答
迈克,
让一个工具专家回到正确的描述错误信息意味着什么。我们会从那里找到问题的根本原因。 罗伯特 以上来自于百度翻译 以下为原文 Mike, I asked a tool specialist to get back with a proper description what the error message means. We will go from there and find the root cause for your problem. Robert |
嗨,迈克,
你能提供以下信息吗? 1。你看到这个问题只有一个项目或你所建的每个项目吗?如果你没有尝试过其他的项目,我会建议你开始一个新的项目,尝试建立空白项目本身。如果该项目从那一定是项目的具体问题。在这种情况下,请附上项目中,你有问题。(如果它是一个秘密的项目,你可以创建一个技术支持的情况下,提交项目)。 2。你的机器上安装了哪个版本的IE? 三。有没有具体的步骤来重现这个问题? 谢谢, 萨钦 以上来自于百度翻译 以下为原文 Hi Mike, Could you please give following information? 1. Do you see this issue with only one project or every project you build? If you have not tried with other projects, I will suggest you to start a new project and try to build blank project itself. If this project gets through then it must be a project specific issue. In that case, please attach the project in which you have issue. (If it is a confidential project, you may create a technical support case and submit project in that). 2. WHich version of IE is installed on your machine? 3. Are there any specific steps to reproduce this issue? Thanks, Sachin |
我今天也有类似的问题。”C:程序 1 柏~共同该~ 3 工具”:中断/异常捕获(代码= 0xc0000005,地址= 0x77a18822)”
0错误,0警告报告但不创建输出文件。 这发生在每一个构建中,包括一个新项目。我用5 sp5.5设计师建造985与Vista的IE 7的企业。 以上来自于百度翻译 以下为原文 I am having a similar issue starting today. "C:PROGRA~1CypressCommonCYPRES~3toolsmake": Interrupt/Exception caught (code = 0xc0000005, addr = 0x77a18822)" 0 errors, 0 warnings reported but output files are not created. This occurs with every build including a new project. I am using Designer 5.0 sp5.5 build 985 with Vista Enterprise; IE 7. |
阿布,
请将您的项目附加到这个线程,以便我们可以把它纳入我们的内部缺陷跟踪系统。 谢谢, 马修布扎 以上来自于百度翻译 以下为原文 ablot, Could you please attach your project to this thread so we can include that into our internal defect tracking system. Thanks, Matthew Buza |
有一个解决问题的办法;我也有同样的问题,编译器完成没有错误,但没有OBJ文件。
埃里克 以上来自于百度翻译 以下为原文 Is there a solution to the problem; I have the same problem, the compiler finishes without error, but no obj-file. Erik |
Eabinder
你能把你的项目附在这份表格上吗?请让我们知道你正在使用的操作系统版本和PSoCDesigner使用的版本。 谢谢, 马修布扎 以上来自于百度翻译 以下为原文 Eabinder, Can you please attach your project to this form post? Please let us know which version of OS you are using and which version of PSoC Designer you are using. Thanks, Matthew Buza |
迈克、阿布和埃里克
我们正站在你们的问题上来帮助你们,我们需要你们的帮助来前进。到目前为止,我们还没有能够复制“中断/异常捕获”(Code=0xC000 00 5,ADDR=0x77 6F2262)的消息。 由于3个不同的用户经历了同样的问题,所以我们可以修复它是非常重要的!我们希望我们的客户愉快地与设计师合作,而不是与任何问题打交道。 你们当中的一个还是更好的请回到我们身边? 与我们的支持团队提交一个案例将是一个伟大的选择提供信息,而不向世界公布您的代码。请将参考CDT 98232添加到您的案例中。 一旦你用CyPress ID登录,你可以在这里提交一个案例: 右下角让你“创造一个案例” 谢谢合作 罗伯特 以上来自于百度翻译 以下为原文 @ Mike, ablot and Erik We are standing by to help you on the issue you have brought up and we need your help to go forward. So far, we have not been able to reproduce the message "Interrupt/Exception caught (code = 0xc0000005, addr = 0x776f2262)" As 3 different users have experienced the same issue, it is very important that we can fix it! We want our customers to be happily working with Designer, not fighting any issues. Can one or better all of you please get back to us? Filing a case with our support team would be a great option to provide the information without publishing your code to the world. Please add the reference CDT 98232 to your case. Once you are logged in with your Cypress ID, you can file a case here: Lower right hand corner lets you "Create a Case" Thank you for your cooperation Robert |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7568浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 15:18 , Processed in 0.832679 second(s), Total 87, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1798
