电子发烧友论坛扫一扫,分享给好友
嗨,大家好,
我在PSoC 5和CY8CITK-01开发工具包上有一个UART的问题。我所做的,是通过一个串行到USB电缆发送数据(Modbus)从PC到设备。当使用RealTealPATH向设备发送数据包时,每一次工作都很好。但是,如果我使用.NETSerialPoT类从C语言应用程序发送数据包,则在设备端会有一些字节被加密。这种情况并非每次发生,但实际上大部分时间都没有。我在我构建的PIC Modbus DEVCE上使用了同一个C应用程序,而且每次都很好用。 实际上,我求助于Java,使用RXTX库将Modbus包发送到设备。但是,Java应用程序也会发生同样的情况。 这是怎么回事,当我使用Realterm时,数据会正确地到达设备,但是当我使用任何其他自定义应用程序时,有些字节会被加密? 请帮帮我 以上来自于百度翻译 以下为原文 Hi all, I have a problem with the UART on the PSoC 5 and the CY8CKIT-001 development kit. What I am doing, is sending (Modbus) data via a serial to USB cable from the PC to the device. When using Realterm to send the data packet to the device, everything works fine, every time. However, if I send the data packet from a C# app using the .net SerialPort class, some bytes get scrambled at the device side. This does not happen every time, but actually most of the time. I used the same C# app on a PIC Modbus devce that I built, and it works fine every single time. I actually resorted to go to Java, using the RXTX library to send the Modbus packet to the device. However, the same happens from the Java app. How can this be, that the data gets to the device correctly when I am using Realterm, but when I am using any other custom app, some bytes get scrambled? Please help me with this |
3个回答
我也运行了同样的C应用程序来查询PIC Micro,每次都非常成功。
难道没有人(也许是塞浦路斯人吗?)谁能帮我解决这个问题? 以上来自于百度翻译 以下为原文 I also ran the same C# app to query a PIC micro of mine with great success (every time). Isn't there anyone (maybe from Cypress?) who can please help me with this? |
这看起来很奇怪。我会和我们的一位应用工程师谈一谈,但我想我们可能需要把这个案子移交给我们的技术支持工具。这将允许我们进行一对一对话,并可能共享项目文件来回。
-博比 以上来自于百度翻译 以下为原文 That does seem odd. I'll talk to one of our application engineers, but I think we might need to move this case over to our technical support tool. That will allow us to have a one-on-one dialog and potentially share project files back and forth. -Bobby |
嗨,是的。请您在这个问题上创建一个技术支持案例,因为我们可能需要调试您的代码。您可以通过设计支持创建一个案例-gt;技术支持-gt;创建一个案例-gt;创建一个案例-gt;选择“技术支持”-gt;输入您的问题的详细信息,附加您的项目并点击CreateMyCase。问候,Kishore。
以上来自于百度翻译 以下为原文 Hi, Yes. Can you please create a Tech Support case on this issue as we may require to debug your code. You can create a case by Design Support -> Tech Support -> Create a Case -> Create a Case -> Select "Technical Support" -> Enter the details of your issue, attach your project and click CreateMyCase. Regards, Kishore. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7572浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6120浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7965浏览 2评论
/9
GMT+8, 2025-12-2 18:39 , Processed in 0.999065 second(s), Total 79, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
478
