我收到一个链接器错误消息,我找不到解决方法 - 这是错误:
运行链接器 clnk -l''C: Program Files COSMIC CXSTM8_16K Lib''-l''C: Program Files COSMIC CXSTM8_16K''-Debug newARMour.sm8 -l .. project -l'' .. .. .. .. .. .. .. .. program files cosmic cxstm8_16k''-mDebug newarmour.map #error clnk:1缺少命令文件 命令:''clnk -l''C: Program Files COSMIC CXSTM8_16K Lib''-l''C: Program Files COSMIC CXSTM8_16K''-Debug newarmour.sm8 -l .. 项目-l''.. .. .. .. .. .. .. .. program files cosmic cxstm8_16k''mDebug newarmour.map''失败了,返回价值是:1 退出代码= 1。 newarmour.elf - 2个错误,0个警告 我通常不运行这种软件 - 我是销售/应用工程师,试图为客户解决问题,所以我不确定为什么我会收到此错误。 我正在使用Cosmic编译器/链接器运行STVD 谢谢你的帮助 以上来自于谷歌翻译 以下为原文 I am getting a linker error message that I cannot find a way to resolve - here is the error: Running Linker clnk -l''C:Program FilesCOSMICCXSTM8_16KLib'' -l''C:Program FilesCOSMICCXSTM8_16K'' -o Debugnewarmour.sm8 -l..project -l''................program filescosmiccxstm8_16k'' -mDebugnewarmour.map #error clnk :1 missing command file The command: ''clnk -l''C:Program FilesCOSMICCXSTM8_16KLib'' -l''C:Program FilesCOSMICCXSTM8_16K'' -o Debugnewarmour.sm8 -l..project -l''................program filescosmiccxstm8_16k'' -mDebugnewarmour.map '' has failed, the returned value is: 1 exit code=1. newarmour.elf - 2 error(s), 0 warning(s) I am not typically running this kind of software - I am a sale/appliction engineer trying to fix a problem for a customer, so I am not sure why I am getting this error. I am running STVD with Cosmic compiler/linker thanks for any help |
1个回答
从链接器的角度来看,错误消息非常明确:您在调用它时没有指定强制的''file.lkf''参数(链接器文件)
如果您使用的是STVD,则解决方案可能位于“项目设置/链接器/输入”选项卡中。 以上来自于谷歌翻译 以下为原文 from the linker point of view the error message is quite clear: you are calling it without specifying the mandatory ''file.lkf'' parameter (the linker file) If you are using STVD the solution will probably be in the Project Settings / Linker / Input tab. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 03:21 , Processed in 0.962432 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
356
