电子发烧友论坛|
我正在为我的项目使用SPC560B-DIS发现板和UDE STK 4.8调试器。
我在调试期间遇到看门狗问题,我已经在窗口模式下设置了看门狗 超时时间为100 ms,窗口为50 ms。 通过分析一个引脚状态,我不会在100 ms后检查看门狗是否复位 在示波器中。在示波器中,我能够在非常短的时间内看到引脚状态变化,但是连续峰值之间的差异准确地达到了100 ms。 我已将FRZ位设为0,因此看门狗计数器将在调试模式下递增。 问题:当我使用调试代码时 UDE STK 4.8,重置正在进行并且是连续的 警告消息显示在日志窗口中,带有时间戳。 但是,当我把断点放在主要位置时,它不会经常发生,而是随机发生 有时在几秒钟内,有时在几分钟内。 但是消息日志中的警告显示频繁。 我不知道这个问题的原因,任何帮助将不胜感激解决这个问题。 以上来自于谷歌翻译 以下为原文 I am using SPC560B-DIS discovery board and UDE STK 4.8 debugger for my project . I am facing issue with watchdog during debugging , i have set my watchdog in window mode with time out period of 100 ms , and window as 50 ms . I am not servicing watchdog to check whether watchdog reset or not after 100 ms , by analyzing one pin state in oscilloscope .In oscilloscope i am able to see pin state change for very short time , but differences between consecutive peaks is coming accurately 100 ms . I have put FRZ bit as 0 so watchdog counter will increment in debug mode . Issue : When i debug the code using UDE STK 4.8 , reset is happening and continuous warning messages are displaying in log window with time stamps . But when i am putting the break point in main , it is not hitting frequently but randomly like sometimes in seconds , sometimes in minutes . But warning in message log is displaying very frequently. I don't know the cause of this issue , any help will be appreciated for solving this issue . |
2个回答
你好Alok,
如果你有一个ramdomly重置问题,你要去哪个IVORx? 检查你的LR,PC .. 有关您的信息,Watchdog将在您的默认配置上禁用调试配置。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Alok , If you have a reset issue ramdomly, which IVORx are you going ? Check your LR,PC .. For your information , the Watchdog is disable on your debug configuration on your default configuration. Best Regards Erwan |
嗨erwan,我之前删除了看门狗de-init。请参阅下面的图片
这里看门狗复位发生在100毫秒,我能够看到警告信息,通过 引脚状态我已确认复位超时为100 ms,但TIMT_Start()之前的断点 每次目标重置后没有击中,有时它会击中断点,也会出现 不同的间隔。 以上来自于谷歌翻译 以下为原文 Hi erwan , i have removed the watchdog de-init previously . Please see the pic below Here watchdog reset is happening in 100 ms and i am able to see the warning message ,through pin state i have confirmed reset time out is 100 ms , but the break point before TIMT_Start() is not hitting after target reset every time , some times it hits the break point and that also with different intervals . |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 04:29 , Processed in 0.757225 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
551
