您好,我尝试用CPLS编译器使用MPLABX,但是编译器没有被MPLABX识别。当打开项目属性时,X8和MPASM编译器是在编译器工具链中出现的唯一一个编译器。我试过将编译器与mpasm一起重新安装到MPLABX v.3.35程序文件目录中,但是仍然没有显示。我试着自己打开编译器,它成功地构建了我的项目,但是不能用PickIt 3来编写芯片,所以我需要让它与MPLABX一起工作。
以上来自于百度翻译 以下为原文 Hi, I am trying to use MPLABX with a CCS compiler, but the compiler is not being recognized by MPLABX. When I open project properties the X8 and mpasm compilers are the only ones that show up under the compiler toolchain. I have tried reinstalling my compiler into the MPLABX v.3.35 program file directory, alongside mpasm, but it still doesn't show up. I have tried opening the compiler on its own, and it builds my project successfully, but does not work with the PickIt 3 I am using to program my chip so I need to have it working with MPLABX. Is there anything I need to do to have MPLABX see the compiler as an option? |
3个回答
嗨,它非常简单-尝试用工具重新安装:setup_mplabx_plugin.exe或在MPLLABX中转到菜单项:tools-.-building tools->并搜索CCS编译器“Add”或“Add custom compiler”——其中之一可以工作。中间带有一条消息,例如“new installed compiler”。您还可以通过注册给定的文件夹来手动搜索。然后您可以将编译器标记为默认编译器。
以上来自于百度翻译 以下为原文 Hi, its very easy - try reinstall with the tool: setup_mplabx_plugin.exe Or go in the MPLABX to the menu item: tools - options - building tools -> and search for the CCS compiler "Add", or "Add custom compiler" -- one of this will work. Or if was installed with the mplabx_plugin you'll find this immediately with a message eg "new installed compiler". You can also search for manually by register the given folders. Then you can mark your compiler as default compiler. Gerald --- |
只有小组成员才能发言,加入小组>>
5238 浏览 9 评论
2028 浏览 8 评论
1950 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3204 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2253 浏览 5 评论
777浏览 1评论
666浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
595浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
676浏览 0评论
576浏览 0评论
GMT+8, 2024-12-23 04:34 , Processed in 1.229657 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
