电子发烧友论坛|
大家好,
我有一个关于VND7140AJ-E的问题,我已将其纳入我们公司的设计中。我多次阅读数据表,因为芯片的最大电流并没有真正说明,就像“内部限制”一样。所以我检查了Iliml和Ilimh参数,他们说明了4Atyp和12Atyp。我需要最大4A,所以这对我的应用来说应该足够了。 该芯片还具有28V的最大电压,足以满足我的24V使用需求。我们组装了电路板并将其放在测试台上。但令我惊讶的是,我不能超过1Amp。我一直试图找出问题所在,所以我取消了VND7140周围的所有组件,并将输入的占空比设置为100%。还是只有1A。 当VND7140在板上时,我注意到的另一件事是,当我降低占空比时,它会持续一秒钟,然后进入故障模式。我认为这可能是因为它测量输出端的低电压,这是由于一组电容器用于将PWM信号转换为模拟DC。这很奇怪,因为数据表没有说明这种保护,并且从电力供应中提取的电流不超过1A。 我测量了恒定电流负载的输出电流。 有没有人有任何想法为什么显示这种行为,最重要的是如何获得当前我真正需要的。 带着敬意, Michel van der Breggen #max-current #protection#vnd7140 以上来自于谷歌翻译 以下为原文 Hello All, i have a question about the VND7140AJ-E which i have incorperated into a design of our company. I read the datasheet several times, because the maximum current of the chip is not really stated as such, just as ''internally limited''. So i checked the Iliml and Ilimh parameters and they stated 4Atyp and 12Atyp. I need 4A max, so this should be more than enough for my application. The chip also has a maximum voltage of 28V which is enough for my 24V usage. We assembled the boards and I put it on the testbench. But to my surprise i can't get more than 1Amp out of it. I have been trying to figure out what is wrong, so I took off all the components which are around the VND7140 and i put the dutycycle on the input to 100%. Still just 1A. Another thing i noticed while the VND7140 was on the board is that when i lowered the dutycycle it would go on for a second and then drop into failure mode. I thought this could be due to the fact that it measures a low voltage on the output, which is due to a set of capacitors used to change the PWM signal into analog DC. Which is strange since the datasheet doesn't state such protection and there is no more then 1A being drawn from the powersupply. I measured the output current which a constant current load. Does anybody have any ideas why this behaviour is being displayed and most of all how to get the current i really need. With regards, Michel van der Breggen #max-current #protection #vnd7140 |
1个回答
嗨米歇尔,对于迟到的回复感到抱歉,但我现在正在读你的问题。告诉我,如果你仍然对提到的设备感兴趣,我会尽力帮助你。
以上来自于谷歌翻译 以下为原文 Hi Michel, sorry for the late reply but I'm reading just now your question. Tell me if you are still interested about the mentioned device and I'll try to help you. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 22:44 , Processed in 1.306706 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
434
