电子发烧友论坛扫一扫,分享给好友
只是一个简单的问题。
我正在使用一个新的CY8CKIT-042 PSoC4先锋套件。 有些事,我无法在它的工作(如一个简单的16x2液晶显示),尽管我已经试过了,我知道尝试一切。 我使用的创造者没有专家(3),或接受,或'包',但我真的达到年底的事情去尝试。 作为最后一招,我拿出放大镜和阅读部分的psoc4芯片。它是。。。 CY8C4245AXI-83ES 我的问题…“ES”代表什么? 如果是我想它的意思,然后我用一个“工程样品”这一局。(或者试着用一个。) 有人能对此有所启发吗?如果_is_工程样品(我已经购买了两(2)先锋套件都有'的部分上),那么这就可以解释为什么我有困难。 谢谢。 詹姆斯 以上来自于百度翻译 以下为原文 Just a quick question. I am using one of the new CY8CKIT-042 PSoC4 Pioneer Kits. There are some things that I am not able to get working on it (like a simple 16x2 LCD display), even though I have tried everything that I know to try. I am no expert using Creator (3.0), or the PSoC, or the 'kit', but I am really reaching the end of things to try. As a last resort, I got out my magnifier and read the Part Number on the PSoC4 chip. It is... CY8C4245AXI-483ES My question... What does the 'ES' stand for? If it is what I think it means, then I am using an 'Engineering Sample' part on this board. (Or trying to use one.) Can someone shed some light on this? If it _is_ an Engineering Sample (and I have purchased two (2) Pioneer Kits - both have 'ES' parts on them), then this may explain why I am having difficulties. Thanks. James |
44个回答
我取得了一些进步,但断点仍然没有发挥作用。
事实上,在API C代码板中断,但所有的BPS已被清除? 我也改变了MimPro 3,看看PSoC 5LP是否引起了问题。不 运气好。 问候,Dana。 以上来自于百度翻译 以下为原文 I made a little progress, but breakpoints still not working. In fact board breaking at API C code, but all BPs have been cleared ? I also changed to Minprog3 to see if PSOC 5LP causing issues. No luck. Regards, Dana. |
Dana
好的,所以有信号在P2线上摇摆。那很好。 1)PSOC4使用的电压是多少?3.3还是5? 2)你使用的是LCD显示器?P/N请-或更好的是-哪一个控制器芯片正在使用的LCD显示器? 我想缩小这个范围。它与PSoC相关,LCD显示相关或电压相关。一旦它缩小了,我就可以集中精力了。 谢谢, 杰姆斯杰克逊 臭氧电子学 以上来自于百度翻译 以下为原文 Dana, Okay - so there are signals that wiggle on the P2 lines. That's good. 1) What voltage are you using for the PSoC4? 3.3 or 5.0? 2) What LCD Display are you using? P/N please - or better yet - which controller chip is being used in the LCD Display? I'm trying to narrow this down. It's either PSoC-related, LCD Display-related or Voltage-related. Once it gets narrowed down, I can focus on that. Thanks, James Jackson Oztronics |
@ Dana,
“事实上,在API C代码板打破”我有一个类似的经验,一旦删除USB端口驱动程序和重新启动PC和重新连接先锋板,错误已经消失。所有的事情都发生在Vista机器上。 鲍勃 以上来自于百度翻译 以下为原文 @Dana, "In fact board breaking at API C code" I had a similar experience once, after removing the USB-Port driver and rebooting PC and re-connecting the Pioneer-board that bug was gone. All happened on a vista machine. Bob |
好,澄清:
我使用的是先锋试剂盒对它的psoc4标记为我一个LCD的自由泳的PSoC连接cy8c4245axi-48es,我需要查找连接然后我建立一个液晶屏,基于freetronics盾(除了背光与D10)我测试了不同的液晶显示器便宜的中国从易趣网,我不知道从- 050盒液晶是控制器(sc1602an * B),似乎是一个ks0066控制器(或兼容)从-001盒液晶(绿森lcm-s01602dsr /),控制器是我找到的一个显示没有规格(20x4不幸),声称有st7066u控制器(http://www.crystalfontz.com/product/cfah2004atmijt),但我需要焊接头上的测试。 以上来自于百度翻译 以下为原文 OK, to clarify:
哦,不,有趣的P/N号码:(再次查看后,验证了LCDWork),并看到它是这一个:HTTP://wwwStalfFunZ.Co /产品/CFAH2004 4ATMIJP,它使用SPLC780D控制器…
以上来自于百度翻译 以下为原文 Oh no, fun with P/N numbers :( Looked again (after verifying that the LCD indeed worked), and saw that it was this one: http://www.crystalfontz.com/product/CFAH2004ATMIJP , which uses a SPLC780D controller... |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7495 浏览 0 评论
2492 浏览 1 评论
2184 浏览 1 评论
4046 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2095 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7965浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6540浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
760浏览 2评论
737浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8394浏览 2评论
/9
GMT+8, 2025-12-18 14:12 , Processed in 0.628418 second(s), Total 51, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2632
