电子发烧友论坛|
嗨,我检查过放大器。
使用HP 437B功率计并且没有输出,所以我想检查一下手机中继器是否有电,它的额定功率为800Mhz,输出功率为26dBm。 我的VNA只能采用25dBm最大值和24VDC,因此我将使用衰减器,但我也应该使用偏置T(我没有)。 我有(HP 85024A)(3Ghz),所以我可以使用连接到VNA输入的有源探头来跟踪电路信号吗? 如果有,我应该采取其他任何预防措施吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I have checked the amp. with an HP 437B power meter and have no output so I want to just to check to see if there is power coming out from a cell phone repeater it is rated at 800Mhz and should have a 26dBm output. My VNA can only take 25dBm maximun and 24VDC so I will use an attenuator but should I use a Bias T also (which I do not have). I have an (HP 85024A) (3Ghz) so can I use this active probe connected to the input of the VNA to trace the circuit signal? If so is there any other precaucions I should take? Thanks. |
2个回答
那个有源探头(由Wayne Fredrick在1983年设计!)对ESD和过功率非常敏感,所以它应该有一个随附的衰减器探头尖端;
用它。 它的最大电压为7 V.在VNA端口上放置一个10 dB的焊盘应该没问题。 以上来自于谷歌翻译 以下为原文 That active probe (designed by Wayne Fredrick in 1983!) is EXTREMELY sensitive to ESD and over power, so it should have an attenuator probe tip that came with it; use it. It has a max voltage of 7 V. Put a 10 dB pad on the VNA port should be fine. |
脑洞大赛9 发表于 2019-2-15 13:14 > {quote:title = Dr_joel写道:} {quote}>那个有源探头(由Wayne Fredrick于1983年设计!)对ESD和过功率非常敏感,所以它应该有一个随附的衰减器探头尖端; 用它。 它的最大电压为7 V. >>在VNA端口上放置一个10 dB的焊盘应该没问题。 我实际上买了这个探测新的条件,所有仍然在密封包装从Uniden关闭。 Thaks Joel然后我将使用衰减器。 以上来自于谷歌翻译 以下为原文 > {quote:title=Dr_joel wrote:}{quote} > That active probe (designed by Wayne Fredrick in 1983!) is EXTREMELY sensitive to ESD and over power, so it should have an attenuator probe tip that came with it; use it. It has a max voltage of 7 V. > > Put a 10 dB pad on the VNA port should be fine. I actually bought this probe new condition all still in the sealed package from Uniden close out. Thaks Joel I will use the attenuator then. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 23:33 , Processed in 1.173443 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3759
