电子发烧友论坛|
你好,
Win8似乎没有识别MinPrim3驱动程序。有没有Win8驱动程序呢?? TJ 以上来自于百度翻译 以下为原文 Hello, Win8 does not seem to recognize miniprog3 driver. Is there a win8 driver it?? TJ |
8个回答
我不想赢得8的驱动还没有发布,看
HTTP://www. CyPress?COM/?应用=论坛&;ID = 2233 &;摆脱= 70652 和最近http://www.cypress.com/?RID=56745 试着在www. CyPress网站发布一个技术案例,并询问Win 8驱动程序的日程安排。 释放。 CyPress网站 “支持” “技术支持” “创造一个案例” 问候,Dana。 以上来自于百度翻译 以下为原文 I do not think Win 8 driver released yet, see http://www.cypress.com/?app=forum&id=2233&rID=70652 and recent - http://www.cypress.com/?rID=56745 Try posting a tech case at www.cypress.com and ask for the schedule of Win 8 driver release. www.cypress.com “Support” “Technical Support” “Create a Case” Regards, Dana. |
谢谢Dana。
我开了一个案子,将张贴他们的回复。 TJ 以上来自于百度翻译 以下为原文 Thanks Dana. I opened a case, will post their response. TJ |
你想尝试一下下面的解决方法:
1)在安装有PSoC程序员软件的WI7机器的C:程序文件(x86) CyPress 程序员3 XX目录下复制“驱动程序”文件夹(或下载附加的“驱动程序.zip”文件,以防安装了PSoC程序员的WI7机器)。2)把它放在你的Win8机器下面的“C:程序文件(x86) CyPress 程序员3。XX”目录(解压缩)驱动程序。zip“文件作为文件夹,如果你使用附件”。3)在Win8机器上的“驱动程序”文件夹中运行“驱动程序.BAT”文件。4)现在使用PSoC程序员的任何工具包(MinPROG套件)应该与Win8 64位机一起工作。当做, 罗伊 传动装置 15.7兆字节 以上来自于百度翻译 以下为原文 Would you like to have a try with below workaround: 1) Copy the "drivers" folder under C:Program Files (x86)CypressProgrammer3.xx directory of a Win7 machine which has the PSoC Programmer software being installed (or download the attached "drivers.zip" file, in case you don't have a Win7 machine which has PSoC Programmer installed). 2) Put it in your Win8 machine under "C:Program Files (x86)CypressProgrammer3.xx" directory(unzip the "drivers.zip" file as a folder if you use the attached). 3) Run the "driver.bat" file in the "drivers" folder on Win8 machine. 4) Now any kit(MiniProg kit included) who used PSoC Programmer should be working with Win8 64bit machine. Regards, Roy
谢谢你,罗伊。这就搞定了,MixPro 3连接起来了。
祝大家新年快乐,万事如意! TJ 以上来自于百度翻译 以下为原文 Thank you Roy. That did the trick and miniprog3 gets connected. Happy New Year, all the best to PSoCers! TJ |
我有完全相同的问题,但是上面的步骤对我没有帮助。真的很令人失望。
以上来自于百度翻译 以下为原文 I am having the exact same issue but the above steps didn't help me. Very disappointing really. |
你好,若泽,
你能用Win8机器提供更多关于失败的信息吗? 有另一个线程谈论这个,HTTP://www. CyPress?COM/?APP =论坛和ID ID=2232和;RID=74548 似乎工作方式是一样的。我已经收到多个成功的反馈,所以,请你给它更多的尝试? 当做。 罗伊 以上来自于百度翻译 以下为原文 Hello Jose, Can you provide more info about the failure with your Win8 machine? There is another thread talking about this, http://www.cypress.com/?app=forum&id=2232&rID=74548 and seems the workaround is same. I have been received multiple success feedback, so, Would you please give it more try? Regards. Roy |
MIXPRO3和程序员驱动程序的问题用程序员3.19.1解决。
如果你有Windows 8.1,那么同样的问题也会发生在这个问题上。这个问题的解决方案在链接HTTP://wwwyCysP.COM/?APP =论坛和ID;ID=2492和;RID=89646。在一个技术支持的案例中,CyPress支持者告诉我,他们将在即将到来的PSoCopter版本中解决Windows 8.1驱动程序的问题。 狂欢 以上来自于百度翻译 以下为原文 Problem with MinIprog3 and Programmer drivers is resolved with Programmer 3.19.1. If you have Windows 8.1, then same problem may occur in this as well. Solution for this problem is available at link http://www.cypress.com/?app=forum&id=2492&rID=89646. In a tech support case, Cypress support person told me that they are going to fix the problem of drivers with Windows 8.1 in upcoming version of PSoC Programmer. -Rave |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7367 浏览 0 评论
2486 浏览 1 评论
2178 浏览 1 评论
4045 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2089 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7851浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6413浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
757浏览 2评论
729浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8266浏览 2评论
/9
GMT+8, 2025-12-13 21:26 , Processed in 1.040781 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
529
