我想购买“Kintex-7 FPGA KC705评估套件”,但我担心设备锁定了许可证的一部分。
如果我意外地将Kintex 7板短路,那么该软件是否可以使用具有相同规格和型号的不同Kintex 7板? 或者如果我购买2个“Kintex-7 FPGA KC705评估套件”,那么每个节点都会有每个节点吗? 在教室环境中,可以在安装软件的不同桌面之间互换主板吗? 每个主板都必须保留其桌面吗? 以上来自于谷歌翻译 以下为原文 I want to buy an "Kintex-7 FPGA KC705 Evaluation Kit" but I am worried about the device locked part of the license. If I accidentally short out my Kintex 7 board will the software work with a different Kintex 7 board of same specification and model number? Or if I buy 2 "Kintex-7 FPGA KC705 Evaluation Kits" would each board with each of the Nodes? In a classroom setting would the boards be interchangeable among different desktops with the software installed? Would each board have to stay with its desktop? |
3个回答
嗨布莱恩,
答案是否定的,设备锁定许可证未锁定到该特定序列号。 这只意味着它被锁定到该设备模型。 课堂中唯一的限制是同一个模型和一个托管节点锁定许可证的桌面。 如果您希望使用不同的桌面,如果您希望移动计算机,则最多允许3个重新托管。 如果这已经回答了您的问题,请通过将此标记为已解决来告知我们,以增强其他用户在论坛上的体验。 谢谢, 德文 - 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi Brian, The answer is no, a device locked license is not locked to that specific serial number. That just means it is locked to that device model. The only restriction in the classroom would be to that same model and a single desktop that the node locked license is being hosted on. If you wish to use different desktops, your license is allowed up to 3 re-hosts if you wish to move machines. If this has answered your question please let us know by marking this as solved to enhance other user's experiences on the forums. Thank you, Devin View solution in original post |
嗨布莱恩,
答案是否定的,设备锁定许可证未锁定到该特定序列号。 这只意味着它被锁定到该设备模型。 课堂中唯一的限制是同一个模型和一个托管节点锁定许可证的桌面。 如果您希望使用不同的桌面,如果您希望移动计算机,则最多允许3个重新托管。 如果这已经回答了您的问题,请通过将此标记为已解决来告知我们,以增强其他用户在论坛上的体验。 谢谢, 德文 - 以上来自于谷歌翻译 以下为原文 Hi Brian, The answer is no, a device locked license is not locked to that specific serial number. That just means it is locked to that device model. The only restriction in the classroom would be to that same model and a single desktop that the node locked license is being hosted on. If you wish to use different desktops, your license is allowed up to 3 re-hosts if you wish to move machines. If this has answered your question please let us know by marking this as solved to enhance other user's experiences on the forums. Thank you, Devin |
只有小组成员才能发言,加入小组>>
2183 浏览 7 评论
2618 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3157 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2213 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
453浏览 1评论
1541浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2187浏览 0评论
516浏览 0评论
1662浏览 0评论
GMT+8, 2024-5-17 06:50 , Processed in 1.091819 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
