电子发烧友论坛|
使用MPLAB X IDE,我在推挽模式A中设置了16F15323:TMR2驱动PWM3外设,它是CWG的输入源。CWG在CWG1A和CWG1B上在引脚RA0和RA1上产生两个脉冲,并且工作良好。然而,当我设置CWG时,PIN管理器也将CWG1in作为RA2上的输入引脚引入。我不想使用这个引脚作为CWG驱动信号来自内部的PWM3外设。PIN管理拒绝删除这个CWG1in引脚,并提出了一个消息:“不能取消选择CWG1in对PIN RA2在PIN管理器。设置“CWG1PPS”有多种选择。在PIN模块模块的设置或注册视图中配置一个可选的“CWG1PPS”值“提前感谢任何帮助从引脚移除CWG1in”
以上来自于百度翻译 以下为原文 Using MPLab X IDE I have setup a 16f15323 in push-pull mode a as follows: TMR2 drives the PWM3 peripheral which is the input source of the CWG. The CWG generates two pulses on CWG1A and CWG1b on pins RA0 and RA1 and that works fine. However when I setup the CWG, the pin manager also introduces the CWG1IN as an input pin on RA2. I don't want to use this pin as the CWG drive signal comes internally from the PWM3 peripheral. The pin manages refuses to remove this CWG1IN pin and comes up with a message: " Unable to deselect CWG1IN on pin RA2 in the pin manager. There are multiple options for setting "CWG1PPS". Configure an alternative "CWG1PPS" value in Setup or register view of the Pin Module module" Thanks in advance for any help to remove CWG1IN from a pin |
1个回答
这个错误是说,PPS(外围引脚选择)寄存器定义CWG1in的端口引脚,不能没有价值。在CWG的设置中,您可以选择不使用该PIN作为输入源。因此,即使PIN被选中,它也不会被使用(除非你想要它)。如果你在其他地方使用同一个PIN(并且可能得到警告),你会看到链表图标,但是不应该通过选择多个引脚来中断。
以上来自于百度翻译 以下为原文 This error is saying that the PPS (peripheral pin select) registers which define CWG1IN's port pin, can't be no value. In the CWG's settings, you can choose not to use this pin as the input source though. So even if the pin is selected, the it won't be used (unless you want it to be). You will see the chain icon if you use the same pin somewhere else (and maybe get a warning), but nothing should break by selecting multiple pins. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 09:11 , Processed in 0.567907 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
414
